adding amps to bose
Old Oct 11, 2005 | 06:17 PM
Y2k2maxse's Avatar
adding amps to bose
theoretically....could u buy the harness to add an amp to bose..and connect an amp the speaker wires at the doors and BOOST the sound coming OUT OF the bose amp so that u get louder sound? would that work?
Old Oct 11, 2005 | 10:38 PM
maxgtr2000's Avatar
KH3 by popular demand
Pretty much, only do it if you have to. My pioneer went south on me this summer so I had to put the Bose back in, I'm currently only running the sub amp off a line converter and just using the regular Bose door and rear deck speakers for highs. If you need to run more than a sub amp just run a line converter from the back speakers and then to your amps/crossovers that way.
Old Oct 12, 2005 | 12:05 AM
kpr10is's Avatar
Why waste your time? Rip that sh!tty Bose out of there and replace it.
Old Oct 12, 2005 | 05:21 AM
TAPOUT's Avatar
You will lose
Actually the answer to your question is "NO".
Old Oct 12, 2005 | 11:26 AM
slickrick's Avatar
+1000 on that comment.
Old Oct 12, 2005 | 04:05 PM
wanaMax's Avatar
how about if you hook up subs in the trunk using the wires that are used to connect the Bose sub?? could you just use the signal wire (or what ever else) that goes into the Bose unit, and put it into aftermarket subs in the trunk??
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
