Battery Terminals
Old Oct 11, 2005 | 06:48 PM
Dev's Avatar
Dev
Battery Terminals
I just purchased a pair of battery terminals to replace the stock ones. For people that have done this before, what did you guys do for the positive side? There seems to be 3 main wire connections attatched to the red plastic cover. What am I supposed to do with those?
Also, for the negative, do I simply cut off the stock terminal and put the wire into my new one? It seems like if I do this, the ground wire doesn't have enough length to even reach the negative terminal.
Any help is appreciated. Also, if you have pictures, that would help as well.
Old Oct 12, 2005 | 07:03 PM
Trevmister1610's Avatar
when i did mine i did it the same time as i did the big three upgrade so i just ran new wire for the ground and didnt have a problem with that.
Old Oct 14, 2005 | 12:26 AM
Dev's Avatar
Dev
Alright I guess I will just replace the ground wire altogether as well.
Did you install a terminal on the positive side? If so what did you do with all the wires going in to the positive terminal? put them all together?
Old Oct 14, 2005 | 07:33 PM
reygarcia's Avatar
Loved by MrGone longtime
what kind of battery terminal did you get? for the positive terminal, just make sure that you have enough wire to get connected.
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
