Audio Tech's (Step in)
Old Oct 12, 2005 | 07:11 PM
99 SE-L
hey guys Iam currently running a Kicker Comp VR12 Subwoofer with a Phoneix gold Amplifier and alot of the time the sub misses the High frequenices, iam wondering what can be wrong if it is doing that Any ideas?
Old Oct 12, 2005 | 07:18 PM
AscendantMax's Avatar
it's not suppose to play high frequencies...
edit: if you mean higher bass frequencies, just tweak the crossovers on the amp til you like what you hear.
Old Oct 12, 2005 | 07:39 PM
99 SE-L
Im sorry i meant low frequencies....
Old Oct 12, 2005 | 07:41 PM
slickrick's Avatar
do you mean low low bass, or the "higher bass"???
Old Oct 12, 2005 | 07:43 PM
99 SE-L
Low low bass
Old Oct 12, 2005 | 07:45 PM
slickrick's Avatar
how big is the box, what type, and how much power is the sub getting?
Old Oct 12, 2005 | 07:50 PM
99 SE-L
1.0/Sealed/300 RMS it hits very hard and clean sometimes it misses it, is it maybe becuase iam bridging the amp?
Old Oct 12, 2005 | 07:51 PM
slickrick's Avatar
so it only misses the low notes on occasions, wheres as sometimes it nails them?
Old Oct 12, 2005 | 07:56 PM
99 SE-L
ye it does it again now
Old Oct 12, 2005 | 08:26 PM
go back and check all connections are secure. sounds like something is loose.
Old Oct 13, 2005 | 11:14 AM
Dohcser's Avatar
It could also be that your electrical or amp cannot produce the power needed to supply the sub with low frequency bass. Also what do you consider LOW LOW Freq? What points do you have your cross-over set at?
gigabyte
Jan 6, 2017 06:05 PM
Fbana41
Aug 29, 2016 12:18 PM
Redfox
Sep 28, 2015 10:41 AM
REDinLV
Sep 28, 2015 12:31 AM
