Need help with my clifford/viper alarm.
Old Oct 23, 2005 | 12:17 PM
NyCzBuBBa's Avatar
I have the clifford Matrix3.5/Vipervx791 my original remote broke and i bought a new one, when I use remote start it doesn't crank all the way. Like if u stuck ur key in then went to start it but didn't hold it till it started. Is there a way that I can make it crank longer?
Old Oct 23, 2005 | 10:27 PM
kpr10is's Avatar
1. Open a door.
2. Turn ignition on with the key, then back off.
3. Hold the valet button. It will chirp once, then twice, then 3 times, then let go of the valet button.
4. Push and release the valet button 5 times, and after you release it the 5th time, push it back down and hold it.
5. Push the unlock button on your remote. The siren should chirp twice.
6. Let go of the valet button, and close the open door. The siren will probably go off for just a second, then act normal.
7. Remote start it and test.
8. Post back results.
-Kevin
Old Oct 23, 2005 | 10:28 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Bitwriter is Sooooo much easier.
Old Oct 23, 2005 | 10:46 PM
kpr10is's Avatar
Indubitably. The CC shop bitwriter works fine for me when I feel the need to use it. But Ive got way more important things I could spend a hundred bucks on right now. Like the double kegger I had at my place last night
Old Oct 23, 2005 | 10:50 PM
AscendantMax's Avatar
jeez...i should copy that down in case i lose my 791 remote...
Old Oct 23, 2005 | 10:53 PM
kpr10is's Avatar
Its all in your manual.
Or here.
http://www.drdetailshop.com/deiinstallguides.htm
Old Oct 23, 2005 | 10:57 PM
heh haven't really read the manual yet. (hell the damn thing is still sitting under my desk waiting to be installed. )
Old Oct 23, 2005 | 11:09 PM
NyCzBuBBa's Avatar
I can't wait to do this tomorrow now it's too late I might wake up the neighbors. Hey my lights used to come on when I remote started it. Now it doesn't I couldn't find it on the list.
Old Oct 23, 2005 | 11:17 PM
Pearl96Max's Avatar
Thats a wiring issue, not a programming feature. Programming is either flashing or solid on.
Old Oct 26, 2005 | 07:46 PM
mattleo's Avatar
if you have achipped key that could be the problem also... it happend with my max... i am a tech at Tweeter and i didnt even realize it ... if it is you need a 556UW to bypass the chipped key and install the ring around your ingnition cylndar
Old Oct 26, 2005 | 08:27 PM
Pearl96Max's Avatar
That only applies to 99s and up.
Old Oct 26, 2005 | 09:54 PM
NyCzBuBBa's Avatar
Ok I did exactly as you told me......But it only starts now 3 out of 5 times. It will start sometimes and sometimes it will just crank for a sec then stop. Then for the next 2-3 times it will do full cranks then go back to cranking for a sec and stopping. What may be the problem?
Old Oct 26, 2005 | 09:56 PM
Pearl96Max's Avatar
bad tach wire connect possibly.
Old Oct 26, 2005 | 10:03 PM
kpr10is's Avatar
If it now starts 3 out of 5 times, how many times did it start before?
Old Oct 26, 2005 | 10:05 PM
kpr10is's Avatar
P.S. To increase crank time another 0.2 sec, do everything I said in post 2, except it should chirp 3 times in Step 5 instead of twice.
You can try setting it to voltage sense
Heres the install manual which has all the menu options in case you need it
http://www.directechs.com/guides/man...N564V_6-03.pdf
Old Oct 26, 2005 | 10:08 PM
Pearl96Max's Avatar
Maximas shouldnt need to extend crank time at all.
Kevin you should know voltage sensing is...teh ghey
Old Oct 26, 2005 | 10:10 PM
kpr10is's Avatar
I agree. The only car Ive needed to extend crank time is my roommates 240, but thats because he has a JDM motor swap running off an Everstart lawn&garden battery because its the only thing that fits in his engine bay.
Yes, but he can try to eliminate causes of the problem.
MIXXMAX
Jul 27, 2002 06:16 PM
Mad Dhan
Jun 11, 2002 10:06 AM
00MAXIMA00
Apr 12, 2002 09:12 AM
chrislee8
Jun 7, 2001 05:24 AM
