HELP -- Carpeting a fiberglass (organic shaped) enclosure
Old Oct 29, 2005 | 02:20 PM
replicant's Avatar
HELP!
I've gone through 3 "sheets" of carpet trying to carpet my fiberglass enclosure. I'm at my wit's end.. and I almost trashed my enclosure from being so pissed off. I finally said EFF YOU and just spray painted it black but it looks like **** as you'd expect. Please tell me the best way to carpet an organic shaped fiberglass enclosure.
Thanks!
Pics of the enclosure are in my signature.
-replicant
check out my ride:
maximapc (blog)
maximapc (newest pics)
Old Oct 31, 2005 | 12:04 PM
replicant's Avatar
Anyone have suggestions? I was thinking of just applying it in small sections and trying to "patch" it together. I know it will look bad but if I can get those seems more towards the back or bottom of the enclosure, it may turn out alright.
Any thoughts?
Old Oct 31, 2005 | 12:42 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
(1) I am sure I can rpvide you with some suggestions
(2) Don't make people go fishing for pictures when you are asking for help.
Old Oct 31, 2005 | 12:55 PM
replicant's Avatar
1.) Thanks so much for your help.
2.) Apologies for my ignorance. A few useful reference images below.
Old Oct 31, 2005 | 01:00 PM
Ok, so when you are applying the carpet, what problems are you running into?
Old Oct 31, 2005 | 01:27 PM
replicant's Avatar
Metal Maxima,
Originally I was going to paint it, but the process of prepping was taking too long for my liking, so I decided I'd find some nice color matched carpet and just carpet it, besides it would help to hide a few gaps that would still show even if I sanded and painted it perfectly. So, this leads to my current problems.. actually applying carpet to this odd shaped behemoth. I went through 3 "sheets" of this carpet trying to get it to apply corrrectly without creases, etc; all of this to no avail.
I am just asking for the best, or at least a good method, for applying carpet to odd shaped sub enclosures.. specifically as you see my sub enclosure is rather odd shaped.
Thanks again for any suggestions.
Old Oct 31, 2005 | 01:32 PM
Well, I woiuld do this:
Take the sub out, and then wrap in carpet as you did the fleece, applying spray glue as you go. Now, there more than likley will be a few "ugly" spots, but move the carpet around until you can do it in a way where the ugly spots can be hidden. A second set of hands REALLY helps on this step. Once you are happy with the dry test, apply your glue, then cut around the circumference of the ring.
Although I am gonna really strongly advocate painting the enclosure...worth its weight in gold even though it's quite time consuming.
Old Oct 31, 2005 | 07:48 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Send it to me Seth, Ill carpet it up in about 15-20 mins
Old Nov 24, 2005 | 08:37 PM
lance3223's Avatar
get it pro. done or its not worth it.
Old Nov 25, 2005 | 08:08 AM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
congrats you made fifteen posts
i would have to say send it to don. Ive been doing this stuff for a long time and carpeting is a second only to vinyling odd pieces. good luck
Old Nov 25, 2005 | 08:55 AM
I don't know if you are still working on this, but laying down a layer of 1/8" foam first will hide all the bumps.
fastcarny
Oct 12, 2015 07:06 AM
jc53
Oct 12, 2015 05:12 AM
sliptap
Sep 30, 2015 05:57 AM
95naSTA
Sep 21, 2015 06:50 PM
sdotcarter
Sep 2, 2015 09:53 PM
