Remote wire for amp
Old Nov 15, 2005 | 08:37 PM
Lawtown's Avatar
Remote wire for amp
I have everything wired up, Bose HU with aftermarket amp and subs running off the rear speakers, but when i turn off the HU the amp stays on. Only when the ignition is in the "off" position the amp is off. I have the aftermarket remote wire connected to the Bose amp remote wire. So i'm stumped!?!? Should I be connectting it to some other wire? Other than that everything works fine. So what gives?
Old Nov 15, 2005 | 08:49 PM
maxgtr2000's Avatar
KH3 by popular demand
I only have a sub amp hooked up but I spliced into the red wire where it plugs into the factory amp. Not sure if it is the same color as in an 03. Sounds like it's some sort of accessory wire and not the remote wire.
Old Nov 15, 2005 | 09:34 PM
kpr10is's Avatar
IIRC the Bose amp 'remote wire' is an accessory, not a remote. Youll be fine the way you have it set up.
Old Nov 16, 2005 | 05:44 AM
Lawtown's Avatar
thanks i'll probably leave it that way, but could there be another wire I could use? I might sound like a Total noob but what is "IIRC"? I see it used alot but never knew what it meant.
Old Nov 16, 2005 | 08:10 AM
kpr10is's Avatar
If I Remember Correctly.
Old Nov 16, 2005 | 08:54 AM
Lawtown's Avatar
OOHH, thanks, learn something new every day!
Old Nov 25, 2005 | 01:19 AM
sodie14's Avatar
assuming you have power antenna...you could jump onto that wire...behind your head unit
Old Nov 25, 2005 | 07:44 AM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
with your radio does the power antennae stay up once the car is on or only when the radio is on? personally i would leave it but i like candy, so...
Old Nov 25, 2005 | 09:11 AM
RA030726's Avatar
I'm nutty for Nissans
at every speaker there are 4 wires, 2 audio for the sound and 2 power for the amp. use the red wire. its the factory amp turn on. dont use the power antenna because either the amp will stay on or it will only work with the radio on.
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
