OT Sub install Question
Old Nov 13, 2005 | 11:21 AM
Kevlo911's Avatar
Kevlo for President
I will be installing some subs in a 2002 Tahoe w/o BOSE but w/ OnStar
http://www.cardomain.com/item/STISWK4
I plan to use that wire kit with the Kicker KX1200.1 amp.
Which LOC do I need?
http://www.cardomain.com/item/STISALOC
http://www.cardomain.com/item/STISLOCII
What do I do about the remote wire to turn on the amp?
Old Nov 13, 2005 | 11:36 AM
ObsidianIce69's Avatar
Far as i can tell the only difference is that the SALOC has independent gains for each channel. I'm no expert but i would consider that a good thing. As for the remote turn on. I would guess you just tap the line that goes active when you turn the key to the ACC position.
Old Nov 13, 2005 | 12:25 PM
Kevlo911's Avatar
Kevlo for President
Also can I tap the factory sub for the LOC or will I have to use the other speakers?
Old Nov 13, 2005 | 05:14 PM
nismos14's Avatar
§è~® f®ÈÄk
The cheaper LOC is fine. The amp turn on lead can be wired up to the power antenna lead behind the stock headunit or any acc wire. As for the wiring of the LOC, I would suggest using the stock speakers rather than the sub because the sub channel is typically filtered and you may not get the best sound out of it. You can of course try it that way first and it may work out well, but keep in mind that whatever crossover frequencies that are running to the stock sub will be run into the amp inputs as well. Most likely all high frequencies above 100hz or so will be filtered out around 6db/octave, PLUS whatever x-over setting you select on the amp. There's also always the possibility that the other speakers are crossed over at higher frequency and that would be bad for the signal going to the amp, this is why I would suggest trying it both ways and seeing which sounds the best. Ideally you want unfiltered sound going into the amp and you want to let the amp do all the frequency cutting.
PH98I30
Jan 9, 2025 08:08 AM
JRod28
Dec 29, 2023 09:56 PM
mikekay
Aug 10, 2015 12:52 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
