Got a little problem sub/amp related
Old Nov 14, 2005 | 04:31 PM
nismos14's Avatar
§è~® f®ÈÄk
First question is, is there any possible way to ADD resistance to my subs but keep them wired the way they are?
Current setup is soundstream 4 channel amp front channels powering my front setup and the rear bridged to my subs. Subs are dual 4 ohm subs wired up to 4 ohm mono load which really measures out to ~3.6. Problem here is that my amp does not like any load below 4 ohms when ran bridged. This is why I want to add resistance to the sub wiring. The amp cuts out completely and goes into protection mode when I turn it up too loud the current setup even though there is no distortion. If I don't run the amp bridged or run the subs in series the output goes way down from the amp and it really sounds bad then.
Sooooooooooooo anyone have any ideas?
Old Nov 15, 2005 | 07:36 AM
nismos14's Avatar
§è~® f®ÈÄk
Basically I'm thinking if I wire in a 1 ohm resistor into the + side of the speakers I'll add enough resistance for it to work... trouble is where can I find a resistor that will handle ~300-500 watts?
Old Nov 15, 2005 | 02:34 PM
maxgtr2000's Avatar
KH3 by popular demand
Man.. what kinda amp is that? I know Soundstream is good but I didn't think they were that picky. Every amp I've had did not complain about 2 ohms bridged even a V-Drive Crunch, where is your gain set at? If anything turn your gain down on the sub channels.
Old Nov 15, 2005 | 02:52 PM
trebor317's Avatar
whats the difference between bridging an amp and not bridging it? Is it better to bridge??
Old Nov 15, 2005 | 04:28 PM
nismos14's Avatar
§è~® f®ÈÄk
It's the soundstream ega4220. I've messed with the gain and all settings. I had this problem with it once before when I had it running each channel bridged to a pioneer spl1500. Really p!sses me off! I'm pretty shocked that I'm having this problem too...
Old Nov 15, 2005 | 04:37 PM
DcMaN's Avatar
sounds to me your ground is insufficent. Check your ground location make sure its sanded and the wires are not loose. Also try with the fronts unplugged and see if it still turns off. If it does then its your subwoofer wiring. Do not use an extra resistor as the subwoofer is not designed to be altered like that. This is why they have Single or dual 4, 2 or even 6 ohm voice coils so that it gives you some flexibility.
Old Nov 15, 2005 | 05:06 PM
nismos14's Avatar
§è~® f®ÈÄk
Ground has been tested/stripped/changed over and over, and with the front's disconnected I get the same effect.
Old Nov 15, 2005 | 08:44 PM
maxgtr2000's Avatar
I would say the amp itself has a problem, probably faulty, I would get with a dealer if possible. Do the front channels cut out too? I would disconnect the subs and turn the volume up and see if it still cuts out. If it does, if you already ruled out ground I would say it is a power supply problem (in the amp).
Old Nov 16, 2005 | 04:56 PM
nismos14's Avatar
§è~® f®ÈÄk
With subs off/disconnected no shutting out. Anytime this amp goes into protection mode all channels shut off. I'm sure my ground is good, it probably is the amp but at this point I can't afford to get a new one and this one is well out of warranty.
Old Nov 17, 2005 | 05:32 AM
maxgtr2000's Avatar
Well since it's a soundstream, it may be worth it to try and get it repaired at an electronics repair shop. I've had amps fixed before and was always charged $60. They would always give me a free estimate first.
Old Nov 17, 2005 | 05:43 AM
nismos14's Avatar
§è~® f®ÈÄk
Well I'll consider that as soon as I get to try it out with one more different wiring setup. Again I've never had a problem with anything that had 4ohm + Still sucks though lol.
carid
Sep 9, 2015 05:06 AM
jfl330
Sep 4, 2015 01:44 PM
Wareagle92
Sep 3, 2015 07:18 PM
