I do not want to make a mistake
Old Nov 21, 2005 | 10:26 AM
wadamax's Avatar
I need help. I don't know a whole lot about how subs/amps react to one another. I got a pretty basic, simple set up. 1 mono channel amp pushing 1 10 inch sub. I was showing a co-worker and he advised that since my sub had dual voice coils, that I should connect the voice coils together instead of using just one set. Will this make any difference? Will this eventually damage the speaker and or amp? Should I not try to fix something that is not broken?
Old Nov 21, 2005 | 10:34 AM
OhOhMax's Avatar
The only thing you have to be conserned about there is if your amp is stable at that ohm rating. Like if your sub is a dual 4ohm voice coil and you wired them together you would be running the amp at 2ohms.
Pluses:
Better clerity, IMO.
Bass will "hit harder."
Better use of your sub/amp.
Downs:
Amp will run hotter.
I always have all my voice coils wired. I heard the difference the first time I went from using one coil to using both.
Old Nov 21, 2005 | 10:46 AM
slickrick's Avatar
if your amp can handle the load then of course. otherwise this is a waste of a sub. what sub/amp do you have?
Old Nov 21, 2005 | 11:01 AM
wadamax's Avatar
THANKS!!
I am not sure if the amp is stable at 2 ohms or not. The amp is a Bazooka ELA150.1 out of Circuit City. Does anyone know? I may call them to find out.
Old Nov 21, 2005 | 05:12 PM
kpr10is's Avatar
Yes, that amp should be stable at 2 ohms, however it is a Bazooka, so dont crank the gains too high or else itll heat up/cut out.
Old Nov 21, 2005 | 05:45 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
alright, maybe its just me, or no1 is paying attention.
NEVER RUN ONLY ONE COIL ON A DUAL VC SUB. its bad joo joo and your manhood will shrink. Alright maybe not but just dont do it. Wire the speaker as listed above and itll last you forever, keep using one coil itll die a young death.
user 11122324
42
Jul 18, 2022 03:35 PM
Need help
23
Oct 2, 2015 08:56 AM
05RLS2
Sep 27, 2015 09:24 PM
ik95
Sep 16, 2015 08:11 PM
