battery wire
Old Nov 22, 2005 | 12:26 PM
Nickel's Avatar
battery wire
where is the easiest way to run a wire from the battery to the trunk in a 96 max??
Old Nov 22, 2005 | 08:49 PM
sunten1
Drill a hole through the Firewall, run the wire under the carpet up the seat, and pull it out into the trunk.
Old Nov 23, 2005 | 06:06 AM
Nickel's Avatar
where is the fire wall??
and dont i need a firewall so the inside of my car dont get wet or something?
Old Nov 23, 2005 | 06:48 AM
ObsidianIce69's Avatar
firewall is the huge metal piece that seperates the engine from the passenger compartment. you shouldn't be gettin water in the engine compartment anyways. You can drill through it. But i don't think you have to. i think you have a fairly large hole down around the bottom of the firewall already, but that might just be the autos. One of the 4th gen guys would have a better idea of the location. If you decide to drill it's pretty easy, just be sure to use a grommet.
Old Nov 25, 2005 | 12:48 AM
sodie14's Avatar
there is no hole in a 4th gen for power wire...well, let me take that back...there is supposedly a hole if you remove the front left weel, and the skirting inside the wheel well and all that...which i think is too much work...just drill a hole (where the clutch pedal would be if its an auto, if not...find a spot!) drill a hole, run your power wire, and then seal it back up if you want...silcone or whatever works for you.
Old Nov 25, 2005 | 09:12 AM
AscendantMax's Avatar
i drilled (this was before i knew i can run it through an existing hole in the firewall). but always use a grommet to prevent any sharp edges from cutting into the wire's insulation.
Old Nov 25, 2005 | 08:46 PM
sickmax's Avatar
aaron lavigne FTG
ill do it for u if u want to take a ride up to East windsor. it'll take me 5 mins 2 do
Old Nov 26, 2005 | 04:37 PM
Batxel's Avatar
blah
yes there is look again!
here is a nice hole to run your power wire in 4th gen maxima up to 2 gauge can fit without modification/drilling etc - just remove the rubber plug
Old Nov 27, 2005 | 01:49 PM
Nickel's Avatar
hmm I was looking at that hole before, where dose that hole end up at??
Old Nov 27, 2005 | 06:32 PM
ewuzh's Avatar
Inside the car behind the steering wheel to the right a little...
I used that hole for my boost gauge vac line.
Old Nov 28, 2005 | 11:07 AM
Nickel's Avatar
I got it threw the hole thanks everyone
~THIS THREAD CAN NOW BE CLOSE~
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
