please help with lighting problem
Old Jun 3, 2001 | 08:05 PM
_DRU_'s Avatar
please refer to this thread, thanks
http://forums.maxima.org/showthread....222#post330222
if that doesnt work, its in the 4th gen forum called "interior lighting question." please help me out, im planning on doing it tomorrow if possible, thanks
Old Jun 3, 2001 | 10:45 PM
jashick's Avatar
A resistor would work but you need to know the resistence of the light in order to calculate the value of resistor to use. But then again, the resistor will be generating heat, not sure how much, but some nonethless. Another option would be to incorporate a voltage regulating circuit... I'll try to draw up a diagram with required part, if I have time.
Old Jun 3, 2001 | 11:20 PM
_DRU_'s Avatar
thanks a bunch
Old Jun 6, 2001 | 05:26 PM
jashick's Avatar
thanks a bunch
Sorry, I forgot about this.
Anyways, um, well the cheapest way to go would be adding a series resistor.
If you know the spec. of the new bulb, then you can calculate what the value of the resistor needs to be.
I calculated the formula for your 9V bulb:
R = (V^2)/3P V=9 Volts
P = bulb power in Watts.
This formula is specific only for a 9V bulb in a 12V circuit without any other loads.
The resistor you select should be a little more than
the value of R calculated above and that's just to prolong the life of the bulb. Not sure how much heat the resistor will give off though.
There are other methods for this circuit... diode, voltage regulator.. but these are all overkills for your application.
tsi6001
Oct 3, 2022 10:23 PM
Roymg
Sep 3, 2018 05:10 AM
Samedi
Aug 13, 2015 04:05 PM
kirkhilles
Aug 8, 2015 10:53 AM
yat70458
Aug 3, 2015 01:16 PM
