Don't Want Aa To See My Atlas Again...
Nov 29, 2005 | 12:45 PM
Alrighty, I got my Atlas 15 repaired and it's in my car. I am going to tune my amp correctly this time. I have the Gain up and everything else at 0. What should I set the "Low Pass" at? Is it basically the same thing as Bass Boost? The higher the Hz I set it at the deeper the sub plays. I don't want to kill it again. Should I not touch the Low Pass? What do you experts do with the it. I should have sunten1 tune my amp soon. HINT HINT Sunny...
Thanks, Aaron
Nov 29, 2005 | 01:35 PM
Quote: Alrighty, I got my Atlas 15 repaired and it's in my car. I am going to tune my amp correctly this time. I have the Gain up and everything else at 0. What should I set the "Low Pass" at? Is it basically the same thing as Bass Boost? The higher the Hz I set it at the deeper the sub plays. I don't want to kill it again. Should I not touch the Low Pass? What do you experts do with the it. I should have sunten1 tune my amp soon. HINT HINT Sunny...
Thanks, Aaron
Put your gains ~1/3 to 1/2 way for starters...adjust if needed from the deck.
80hz is universally a good xover point for the car.
What amp?
What deck?
Nov 29, 2005 | 01:41 PM
low pass is the crossover for the sub. high pass is the crossover for the full range speakers.
if you have a separate crossover for the speakers set them where the sub leaves off.
i have my HU set around 160hz so the sub works below the cut off and the componets work above the cut.
Nov 29, 2005 | 01:55 PM
Quote: i have my HU set around 160hz so the sub works below the cut off and the componets work above the cut.
You dont like up front midbass?
Nov 29, 2005 | 02:05 PM
stick with what Manny says...and your sub will be fine. no bass boost under any circumstance.
Nov 29, 2005 | 02:20 PM
Ok, thank you guys!
Nov 29, 2005 | 02:38 PM
Quote: You dont like up front midbass?
my speakers are still bose and they dont like it. i would rather have a nice clean system than a farting, loud & bassy one. ive been working on the stereo one piece at a time. componants will come some day but its not on my list.
Nov 29, 2005 | 03:12 PM
Quote: my speakers are still bose and they dont like it. i would rather have a nice clean system than a farting, loud & bassy one. ive been working on the stereo one piece at a time. componants will come some day but its not on my list.
that sucks...all the atacks coming from behind you
i've had 4" mids crossed lower than that
Nov 29, 2005 | 03:23 PM
honestly? what is the rms rating on the sub? from there get a multimeter and set the gains for below the rms rating. As well if the enclosure is ported ensure you have a ssf as to not wildly accelerate the motion of your woofer uncontrollably.
check here for steps
Gain
Nov 29, 2005 | 03:29 PM
Quote: As well if the enclosure is ported ensure you have a ssf as to not wildly accelerate the motion of your woofer uncontrollably.
that'll only be a prob if he play something that dips below the tuning freq of the box.
are you ported Black Maxima?
Nov 29, 2005 | 03:32 PM
hes ported...
Nov 29, 2005 | 04:14 PM
Quote: that'll only be a prob if he play something that dips below the tuning freq of the box.
i know mushroomed coil, slamming, etc been there done that got the t shirt and trying to keep him from joining the club lol. It was a long time ago. Now I just heat coils past their thermal cap
