Is there a way to see if the subs are blown?
Old Dec 1, 2005 | 03:17 PM
slnned's Avatar
Last year I had replaced my cdplayer in my 04 max two times due to skipping and music only playing on the right speaker. Now i noticed for a long while that theres only music playing from the front and the door speakers not the back. You can't hear anything from the back. Is there a way to check if they are blown, or might it be that the dealership wired the subs wrong after replacing the cd player? Sorry if this sounds stupid. But im trying to get to know cars a little more. Thanks
Old Dec 1, 2005 | 04:04 PM
Pres7's Avatar
turn on your stereo and stick you head in the trunk. Youll be able to tell if the subs are workin or not. if you cant hear them gently touch them with your finger if there is any movement at all they are working..
Old Dec 1, 2005 | 07:15 PM
slnned's Avatar
Thanks =], I'll give it a try tomorow morning.
Old Dec 1, 2005 | 07:52 PM
MAXIE06SE's Avatar
Or put a cd in with alot of Bass!
Old Dec 1, 2005 | 08:23 PM
slnned's Avatar
When Im driving theres alot of bass upfront, IM not sure about the back it just sounds like its coming only from the front =(... Im thinking about getting some subs or amp. Im very new to that stuff though =(. I guess I should surf the net for hours on that stuff =P
Old Dec 1, 2005 | 08:29 PM
NismoMax80's Avatar
SuPeRmOd
did u check the fade?
i would just have dealer look at it.
Old Dec 2, 2005 | 03:43 PM
slnned's Avatar
We'll way before I checked the fade, I noticed when it was all the way in the front changing it towards the center for 3 notches does not make a difference. When it is all the way at the rear, You can Hear the fade slowly coming back after 3 notches to the center... sorry if this sounds confusing..
Old Dec 2, 2005 | 03:56 PM
AscendantMax's Avatar
eh? so fading works or not?
Old Dec 2, 2005 | 04:13 PM
Nickel's Avatar
fade you sound into the back and stick your head into the trunk and see if you could hear anything then touch them to feel them movie if that dosent work then play with the wires and see if they make any other sound.
Old Dec 2, 2005 | 07:54 PM
DcMaN's Avatar
take a 9v battery and and try to "pop" the rear speakers by running a positve and negative off the 9v battery to the positive and negative of the speaker. If they pop you know the speaker voice coils are good.
Old Dec 6, 2005 | 11:18 PM
cmosanna's Avatar
It sounds like you are not getting any sound to your rear speakers and it is most likely in the wiring somwhere. YOu just have to start tracing it from one side or theother until u find the problem
Old Dec 15, 2005 | 02:25 PM
sodie14's Avatar
put a multimeter on the connectors to each speaker...do an ohm check. the reading should read the impedence of the speakers (4 ohm, 2 ohm...whatever they are) if it comes up with nothing, than you have a blown speaker
Floktndr
Nov 30, 2015 07:48 PM
Redfox
Sep 28, 2015 10:41 AM
homewrecker
Sep 24, 2015 07:01 PM
TxBroncosFan
Sep 21, 2015 06:54 PM
Maxie40
Sep 14, 2015 11:28 AM
