Broken Bose
Old Jun 4, 2001 | 07:38 AM
JeepRage's Avatar
i have two 10" JBLs running off the factory bose system, it sounds decent for now, until i redo the whole system. my question is that my stock bose head unit has an intermittent display and cd player takes many tries to get it to play. i think the laser needs to be aligned. about the display, has anyone had this problem, how was it fixed, and how much $$?? dont wanna break the bank yet, stereo isnt getting done till probably the fall.
thanks, Hall
Old Oct 26, 2007 | 05:21 AM
Teaner's Avatar
2003 Nisan Maxima
many times the bose system just dies. try unplugging your battery and reconnecting it. sometimes this will work. but a majority of the time its just bose. the unit probably needs to be replaced i would suggest just buying a new aftermarket radio. it isnt worth fixing it.
Old Oct 26, 2007 | 06:10 AM
nismos14's Avatar
§è~® f®ÈÄk
Just replace with an aftermarket radio.
Old Oct 26, 2007 | 08:04 AM
InfQX4's Avatar
Aftermarket radios have neat features like ipod connectors and bluetooth capabilities
Old Oct 26, 2007 | 10:02 AM
svojs's Avatar
Go aftermarket HU!!!
Just replaced the "CD Err" Blose with a SONY HU. Sound much better than Blose. Though the original Blose is pretty good, the aftermarket one is even better.
Old Oct 29, 2007 | 06:52 AM
max ride 41's Avatar
how are you running subs off of your bose head unit??? i know there's a box you can buy that allows you to do it but it's like 350.00 cause my brother in law had 1 in his 03. he tried talkin me into it and i just put a new pioneer in mine.
Old Oct 29, 2007 | 06:55 AM
nismos14's Avatar
§è~® f®ÈÄk
Bose uses low level outputs from the HU to the amp(s). You do not need ANY adapter to tap signal for your amps to power subs.
Old Nov 8, 2007 | 03:59 PM
drepdem's Avatar
I had the same problem and I put a new HU in my 97, and now I have no sound!
New HU starts up fine and plays, but nothing comes out of the speakers, not even a pop or crackle. I wired all the speakers up, and even if I wired something wrong I should be getting some sound... I don't get it.
Old Nov 8, 2007 | 04:43 PM
drepdem's Avatar
OK, so it's looking like I either have to buy something to bypass the individual amps on the speakers, or put new speakers in, is that correct?
If so, how much does it cost do bypass? I have some extra speakers, just not sure if they'll pump as good as the bose.
Old Nov 10, 2007 | 05:01 PM
Punky's Avatar
theres a few options:
after market HU + scosche or some other adapter (basically 2 x 2 channel line in convertver)
this way you don't have to get a new amp, i did this in my old maxima sound quality is fairly decent actually.
Another is to get a sound processor and send the signal to the stock amp, this works well too.
Or get a new HU + new AMP as well.
Old Nov 11, 2007 | 07:18 AM
Strontium's Avatar
Holy NECRO, Batman!
Old Nov 12, 2007 | 01:16 AM
idtag's Avatar
Is it really worth the money to keep the Bose? Even when mine was working ok it still wasn't great sounding.
Old Nov 16, 2007 | 11:22 AM
anngold's Avatar
Check out aftermarket for some good deals.
Old Dec 19, 2007 | 02:37 AM
impact'sa33's Avatar
just installed my aftermarket HU and no problems had the same problem as you its better just to go with a aftermarket
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
