Does anyone have a site for rebuilding an amp?
Old 01-05-2006, 09:34 PM
  #41
§è~® f®ÈÄk
nismos14's Avatar
computer repair != amp repair. That is my point.
nismos14 is offline
Old 01-06-2006, 09:54 AM
  #42
BigLou93SE's Avatar
When I get back to school, I'm going to take out that resistor, and I will post pics of how the board looks. It's hard to tell exact damage on the board, so I'm going to wait to see what's underneath the resistor.
BigLou93SE is offline
Old 01-06-2006, 09:56 AM
  #43
§è~® f®ÈÄk
nismos14's Avatar
Alright, keep us posted.
nismos14 is offline
Old 01-17-2006, 08:53 PM
  #44
BigLou93SE's Avatar
Just got back from taking that resistor out. It looks to be a 10 ohm resistor, so I will either buy/have one of my friends take one from their lab a 1/2 Watt, 10 ohm resistor. The board is burned, but I am going to keep my eye on it to see how it goes. Here are two pics after taking that resistor out. Another note: one of the solder points literally popped off without any heat, so there wasn't a great connection either.
Old 01-18-2006, 08:25 PM
  #45
§è~® f®ÈÄk
nismos14's Avatar
hmm the wire that says w113 looks pretty badly burned too.
nismos14 is offline
Old 01-18-2006, 08:56 PM
  #46
BigLou93SE's Avatar
I will look into it tomorrow, good catch. I don't keep the amp in my room anymore since it was a pain to carry it to the room where I would work on it.
On another note, my friend should be getting that resistor from a lab at school (we figure paying 30g's for college should justify a 50 cent resistor) soon, and we'll have it back together in no time.
If I remember correctly, my friend said that not only the casing was cracked, but the resistor was as well. It was completely shot. I'll post another update when I look at W113, or when I get that new resistor in. THanks for the look.
Man, I just hope this thing finally works andI get to hear my sub at a fraction of its potential...without setting anything on fire as I've been warned...
Old 01-18-2006, 09:00 PM
  #47
§è~® f®ÈÄk
nismos14's Avatar
Lol good luck bro!
nismos14 is offline
Old 01-22-2006, 12:02 PM
  #48
BigLou93SE's Avatar
Fixing my amp was a success…sort of. I still haven’t been able to try it out, and see if the problem is taken care of. Basically, everything that I thought was wrong with this resistor point, is fixed. Whether or not this was the only problem with the amp will determine if we actually fixed it or not.
Basically, we figured the resistor to be a 10 ohm resistor, ½ watt. Just as I was readying myself to solder the new resistor in (I thought this was the only task we had to do in order to fix the problem), I noticed that the underneath original solder points, the copper “lines” (for lack of a better word) had been lifted. In the following diagram, these are the red x’s.
The rest of the symbols are as follows: Red X – broken copper line; Silver dot – unaffected solder points; Black Dot – Original solder points for the burnt resistor; Green line – copper lines.
What we did: Since the original solder contacts were messed up, we soldered the left resistor point to the silver dot on the left. For the right contact, we soldered directly to the right solder point (on the green line with the rightside black dot). Because the line was broken at the solder points, we took shielded wire, and connected the left side solder point, to the next available solder point on the board, following the copper lines downward. All this can be better described with the pics.
I also forgot – when I said that these guys worked on their computers, I forgot to say that their major is actually electrical engineering, so this was right up their alley. I only remembered this when my friends knowledge showed itself when explaining everything to me.
In all, I learned A LOT from working on this board, and my only hope now is that the sub is powered when I install the amp again in two weeks or so when I go home (my car was too packed to carry my sub, and I couldn’t care less since this amp didn’t work and my old one is a piece). Thanks for everyone’s help and patience, and I will update this thread yet again when I get to test out the amp.
Old 01-22-2006, 01:20 PM
  #49
Chocolate_Boi_1Der
Cant_Get_Ryte's Avatar
cant wait to see the results, just keep an eye on it with the back open for a while before pushing it hard or walking away from it
Cant_Get_Ryte is offline
Old 01-22-2006, 03:24 PM
  #50
BigLou93SE's Avatar
That was exactly my plan. I can't wait to go home to put this sub in. It will literally be for testing only, as the power/ground wires are only 8ga. But at least I will know.
Old 01-23-2006, 08:54 PM
  #51
memphis_sktr's Avatar
You could have used a stress relieve mount for the resitsor bc it it bigger than the lenth of the holes. You couldn't find any micro components instead of mini components. Also, what type of board is that? I work with epoxy boards everyday, and you could have fixed the burn marks if you had more time. I love to see other people trying to fix their things with the same things I have to fix everyday. So what exactly does classes of the electrical engineering. I want to work towards this as a carerr. Just wondering.
memphis_sktr is offline
04-16-2020 05:15 AM
sliptap
09-30-2015 05:57 AM
Pied
09-26-2015 03:29 PM
Tmax78
09-25-2015 09:07 PM
Quick Reply: Does anyone have a site for rebuilding an amp?
