does the 2000 non-bose have rca outs?
Old Dec 16, 2005 | 12:06 AM
Supermax95's Avatar
as title says, 2000 non-bose (se model if it makes a difference). I'm installing a system in my freinds maxima and we need to know whether or not he needs another deck.
thanks in advance.
Old Dec 16, 2005 | 01:57 AM
sodie14's Avatar
it does not have RCA's so you need to either go with a different head unit, or put line-out converters on it
Old Dec 16, 2005 | 08:25 AM
KyMan's Avatar
I know the sound quality with the line-out converter will be inferior to an aftermarket deck, but will it be terribly noticable if I'm just running stock speakers and a ID12 sub? Or would you just use the speaker/high level level inputs on the amp instead of RCAs? Thanks.
Old Dec 16, 2005 | 07:01 PM
Supermax95's Avatar
I personally would never get a line out converter.....unless ofcourse i had a high end car that i wanted to keep as stock as possible.
Old Dec 21, 2005 | 02:53 AM
SEmy2K2go's Avatar
Go BUCKS!!!
It's not all that noticable until you actually upgrade to an aftermarket HU. The downside of using your OEM non-bose is, that the 6.5"s will not sound all that great against the added equipment ie sub. If, however, you just add the sub and use the OEM speakers and HU, I don't think you'll notice much in the way of "worse" SQ by using the interface. Maybe just save up for some aftermarket stuff.
MikesChevelle
Nov 23, 2024 11:17 AM
kjlouis
Nov 24, 2018 06:09 AM
maxocar
Aug 21, 2015 12:57 AM
jholley
Aug 11, 2015 09:38 AM
niZ
Aug 7, 2015 10:18 PM
