Install help real quick - amp protect
Old Dec 22, 2005 | 05:16 PM
djfrestyl's Avatar
Suspension Yoda
0 gauge split to 2 4gauge
one amp wont turn on (directed one), the other goes immediately into protect mode.
RCA's are not hooked up, neither are speaker wires. just power, ground and remote turn on.
JL e4300 btw, and a directed 350d
just throw ideas out there, im absolutely stumped
(this is an install im doing right now, im baffled and the kid is probably very upset)
Old Dec 22, 2005 | 05:35 PM
filtor1's Avatar
Are the amp new or used? Does he know or you know that they are both good amps, bench tested?
Try hooking them both up independant of each other. Check them both.
Old Dec 22, 2005 | 06:07 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Some amps go directly into protect mode if no inputs/outputs are detected
Old Dec 22, 2005 | 06:55 PM
Igor911's Avatar
Did you use a relay on your remote turn on??? You might want to try that....
Old Dec 22, 2005 | 07:00 PM
How would that help?
I'm quite sure Nilesh would have considered that before asking for help, he is quite the capable installer.
Old Dec 22, 2005 | 08:33 PM
djfrestyl's Avatar
Suspension Yoda
Turns out it was the amp itself.
I started off using a relay but then noticed that the supposed remote turn on didn't infact do its job correctly, so I just tapped ignition right off of the main harness under the steering column.
3-4 hours of troubleshooting and I all my wiring was right on the entire time. I could have been with my girl or bowling with Don. asdjhdfjhgsdgf
grrrr.
thanks all for the help
Old Dec 22, 2005 | 08:55 PM
AscendantMax's Avatar
ah sucks to hear
Old Dec 22, 2005 | 09:00 PM
djfrestyl's Avatar
Suspension Yoda
No worries, Gordon. Just another example why its best to purchase from authorized dealers.
Old Dec 22, 2005 | 09:03 PM
Damn, man. Sorry to hear.
Old Dec 22, 2005 | 09:06 PM
djfrestyl's Avatar
Suspension Yoda
Happens. Just glad its done with.
So, gentlemen, what's on the postwhore agenda for tonight?
Old Dec 22, 2005 | 09:14 PM
Pearl96Max's Avatar
I tend to get a bit irritable
yup, yup 10+ hours spent in my garage for pretty much nuttin...
Old Dec 22, 2005 | 09:15 PM
+1 to that.
it's not friday yet
Old Dec 22, 2005 | 09:18 PM
djfrestyl's Avatar
Suspension Yoda
Most of the day was productive, just the last few hours were a waste.
And, technically it IS friday.
Old Dec 22, 2005 | 09:19 PM
Pearl96Max's Avatar
But a few hours that could have been spent doing something more enjoyable...
Old Dec 22, 2005 | 09:20 PM
Pearl96Max's Avatar
BTW Nilesh you left $20 here, come get it whenever.
Old Dec 22, 2005 | 09:27 PM
Igor911's Avatar
are u stupid? When connecting more than 1 amp, you are supposed to use a relay with the remote turn on wire.
Maybe you should ready 12volt forums once in a while....or ask any pro installer.
Old Dec 22, 2005 | 09:28 PM
Pearl96Max's Avatar
Hey Newb, why would You call someone else stupid with false info? Cmon Igor, you should know better than that.
Old Dec 22, 2005 | 09:29 PM
slickrick's Avatar
so can we turn this into a post ***** thread? which amp was the messed up one?
Pearl96Max's Avatar
O ummm I also asked a "pro" he said its fine.
I love talking to myself....
Old Dec 22, 2005 | 09:30 PM
Pearl96Max's Avatar
The JustLousy
Old Dec 22, 2005 | 09:31 PM
i'm running two amps with no relays on the remote wire...no issues here...
Old Dec 22, 2005 | 09:33 PM
Igor911's Avatar
sure it's fine but best with a relay...
Old Dec 22, 2005 | 09:34 PM
Pearl96Max's Avatar
Gordon, you shouldnt. According to Igors theory you must have a relay for more than One amp. Im assuming this refers to Any amps used as well, despite their turn on capabilities.
Old Dec 22, 2005 | 09:35 PM
Pearl96Max's Avatar
According to who???? Its not gonna make a bit of difference. 12V is 12V no matter how you spin it.
You do realize your fighting an uphill battle here right?
Old Dec 22, 2005 | 09:37 PM
Igor911's Avatar
http://www.teamrocs.com/technical/pa...lay_basics.htm
Just one of the many pages found on google. If you keep splitting a single 12v source, it's bound to lose current down the line.
Old Dec 22, 2005 | 09:39 PM
djfrestyl's Avatar
Suspension Yoda
A relay would have been used if we didn't use a high current source.
The Blose factory turn on wire is weak, yes.
Don the $20 is yours.
Looks like Don already got started on the whoring
Old Dec 22, 2005 | 09:40 PM
slickrick's Avatar
i knew it was the JL...arguing with Don is like competing in the special olympics, even if you win you're still retarded.
Pearl96Max's Avatar
Dude, the money is yours. I read the note with it and dont care. Its YOUR money. So take it Bish
Old Dec 22, 2005 | 09:41 PM
djfrestyl's Avatar
Suspension Yoda
So when it loses current enough to not be able to turn on an amp, throw a relay in. No problems with two amps here, and I could probably get a third too.
so no harm when NOT using the relay eh? both my amps turn on just fine. and each one is getting ~12 volts when i checked
Old Dec 22, 2005 | 09:42 PM
djfrestyl's Avatar
Suspension Yoda
It was a JL e4300.
Old Dec 22, 2005 | 09:44 PM
Igor911's Avatar
When I had just 2 it was fine also. But when I got 3, I noticed that each was getting less voltage. To stay safe in the long-run, I used a relay. Now each of the amps gets almost equal power.
To sum it up, yes...its fine to not use 1 but it's always better to have 1.
Pearl96Max's Avatar
Hmmm.. dont need to read it its common knowledge. ALthough in YOUR words....
KEEP SPLITTING I dont see any of that with TWO amps. But hell what do I know?
Old Dec 22, 2005 | 09:45 PM
Pearl96Max's Avatar
And if you had amps that had a slower turn on this wouldnt be a problem. I always did love the POP on with PG Octanes.
Old Dec 22, 2005 | 09:47 PM
Igor911's Avatar
I have 0 problems with any of the PG amps. They turn on just fine.
Old Dec 22, 2005 | 09:48 PM
Pearl96Max's Avatar
Turn on capabilities play a factor as well. Rule of thumb for me is adding a relay with more than 2 amps. Especially some of the cheaper ones with a faster turn on. 3+ amps all quickly drawing that current will typically leave your remote output lifeless. Hence the need for a relay.
Pearl96Max's Avatar
Im sure they do, Very quickly.
Old Dec 22, 2005 | 09:49 PM
nismos14's Avatar
§è~® f®ÈÄk
Ooooo you gonna ban him for that? I thought you were gonna ban me for my post in Avi's thread!
Old Dec 22, 2005 | 09:50 PM
interesting thread...
how much power does an amp usually need on the remote wire to turn on?
Ugh. I'm only turning on an LCD, DVD Player, Arc Audio 4150/2500XXK, and an AltoMobile Drive 30 with no issues whatsoever. So where does it start losing current, then? That looks like a hefy equipment list to me.
