Do i need a capacitor?
Old Jun 5, 2001 | 09:16 PM
j2chan's Avatar
My system is going to be powered by a Rockford Fosgate 250a2 and a 600a4. Do i need a capacitor for this install? If so, what kind? Thanks!
Old Jun 6, 2001 | 05:01 PM
Micah95GLE's Avatar
Install the system first, then see if you need a cap. Run the system at full blast with the other accessories on and test the charging system with a multimeter. It's an easy thing to add if needed. The Maxima has a fairly strong alternator, so you might not need a cap. I don't use one.
Old Jun 9, 2001 | 04:35 PM
CanuckAMP's Avatar
I agree with Micah. Try it out first and see what happens. for the most part you should be fine. I recommend upgrading the car's negative battery terminal wire and alternator ground wires to at least 6G but preferrably 4G.
If then you have a power problem where your lights dim then think about the addition of a capacitor.
1MAX2NV
Dec 6, 2002 01:33 AM
mb1
Aug 26, 2002 12:38 PM
DaveGrun
Jul 23, 2002 06:34 AM
D1NOnly34
Jun 21, 2002 02:38 AM
Nick97SE
Jun 3, 2002 09:07 PM
