Poor sound quality from aftermarket stereo
Old Jan 3, 2006 | 10:22 AM
Rick James's Avatar
I installed an Alpine 9860, JL audio e4300 4 channel and a set of Alpine Component Type-R's in the front and Type-S's in the back deck, and it is not loud enough.
I have to max my deck out at 35 which is the max on the alpine deck and the stock bose system was louder.
Does anyone have an idea?
Old Jan 3, 2006 | 10:34 AM
shorty3870's Avatar
Who installed it for you? (Please don't say the Canton Jo Di's) Check to make sure the gains are set correctly. You shouldn't bring the volume above ~3/4 on the headunit, otherwise the signal will likely start to clip.
Old Jan 3, 2006 | 10:38 AM
filtor1's Avatar
I have a ton of experience with the Type-R componenets. They are a pain to tune. Start by dialing in your gains. It will take some time to do it properly.
Old Jan 3, 2006 | 11:28 AM
Rick James's Avatar
I have the amp installed under the passenger seat.
Could the heat vent affect it?
The gains are about set half way. I turned them up all the way when i 1st noticed the problem but it didnt make MUCH of a difference. ( the volume went up, but not by much.)
BTW circuit city did the install and used the factory bose wiring for the speaker wire.
Old Jan 3, 2006 | 01:46 PM
shorty3870's Avatar
Where did they ground the amp? (Is it bare metal on the chassis?) Make sure all the speakers are hooked up too (use the balance/fader).
Old Jan 3, 2006 | 02:08 PM
Rick James's Avatar
Its grounded to the seat rails.
Old Jan 3, 2006 | 03:46 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Its Alpine....
Old Jan 3, 2006 | 04:23 PM
shorty3870's Avatar
Originally Posted by Pearl96Max
Its Alpine....
He's got a point.. more importantly, installed by circuit city, which makes the wiring somewhat suspect. offhand i don't know how much power is recommended for the alpines, although as far as i know, the JL should put out about what its rated for.
Old Jan 3, 2006 | 06:17 PM
Rick James's Avatar
Its Alpine....
Should I replace the deck or components? (please dont say both.)
How do we know its not the amp?
Old Jan 3, 2006 | 06:18 PM
1996blackmax's Avatar
I see things have not changed at CC. The one time a paid to get an amp installed it was by them. Not only did I have to rewire my stuff, I had to go back to get the actual RCA's I paid for. They gave me the cheapest ones.
Old Jan 3, 2006 | 11:28 PM
filtor1's Avatar
The Type-S coaxials for the rear doors are fine, I would look into some new components up front.
Old Jan 5, 2006 | 05:46 PM
Tigger's Avatar
I would check to see if they managed to wire the speakers in the correct polarity. If they used the stock wiring, it would be fairly easy to wire a couple in reverse. If the amp has an impedance switch make sure it's correct. Make sure there are no hi or low bypass settings on.
Old Jan 5, 2006 | 08:32 PM
Pearl96Max's Avatar
An impedance switch? Thats a new one for me...
user 11122324
42
Jul 18, 2022 03:35 PM
chisam14
Nov 6, 2018 08:56 PM
Need help
23
Oct 2, 2015 08:56 AM
Andy29
Sep 29, 2015 05:32 AM
EdRomo86
Sep 12, 2015 07:49 PM
