pioneer detachable face?
Old Jan 7, 2006 | 07:25 AM
USPharmD's Avatar
i got the car with a pioneer deh-p4600 headunit. how the hell do I detach the faceplate on it? i'm an idiot. thanks.
Old Jan 7, 2006 | 07:41 AM
nismos14's Avatar
§è~® f®ÈÄk
It may not have detachable face. My friends 470mp doesn't.
Old Jan 7, 2006 | 10:24 AM
USPharmD's Avatar
http://www.dealtime.com/xPF-Pioneer_..._MP3_Receivers
it says that the face is detachable, but it doesn't look like it can really detach. who knows? noone with this headunit?
Old Jan 7, 2006 | 10:57 AM
nismos14's Avatar
§è~® f®ÈÄk
There should be a button on it that says open hit that. If its not that one there should be another one below or above it in the same general area.
Old Jan 7, 2006 | 11:01 AM
nismos14's Avatar
§è~® f®ÈÄk
Looks like you should be able to hit the open button then pull straight back on the face to get it off.
Old Jan 7, 2006 | 11:24 AM
1996blackmax's Avatar
My Pioneer did that, but you had to also push a button on the back of the face to release it.
Old Jan 7, 2006 | 03:29 PM
USPharmD's Avatar
figured it out..just open it like you're putting in a cd then pull it straight out.
Old Jan 7, 2006 | 10:15 PM
nismos14's Avatar
§è~® f®ÈÄk
They reserve the extra push button for the motorized/ "higher end" units. The cheapies get the better release, IMO. I never did care for that button, it really seemed to flimsy.
Old Jan 8, 2006 | 07:30 AM
Agreed, I also did not like that button on the back.
Old Jan 8, 2006 | 11:23 AM
USPharmD's Avatar
is it common for these headunits to go bad? i think the connector between the faceplate and the unit is loose, because the screen shuts off every once in a while when i push a button. this is my first pioneer headunit, so i don't know if it's common or if there is a way to fix it easily.
Old Jan 8, 2006 | 12:34 PM
nismos14's Avatar
§è~® f®ÈÄk
It's not TOO common, but sounds like the contacts need to be adjusted/fixed.
Old Jan 8, 2006 | 01:27 PM
Try cleaning them as well. I did this on an old Kenwood of mine. The display would sometimes turn off when I pushed the buttons. I used some alcohol and a q-tip. Maybe not the best combo, but the HU worked great after that.
worldwiderecognized
Sep 30, 2015 01:16 PM
jaydot901
Sep 29, 2015 01:18 PM
