How do i power amp from inside home???
Old Jan 14, 2006 | 10:31 PM
hollaatchaboi's Avatar
i have an 8" sub and a 200 watt 2 channel amp. For now, i just wanted to put this in my room. I have everything hooked up, but i need a power source for the amp. I've tried the ac-dc converters at radio shack but theya re only 1500 mA and the subs keep cutting on and off. What can i use that has ample power and will change 120v to 12 v to power the amp?
Old Jan 14, 2006 | 10:53 PM
D-Bo's Avatar
Droppin logs
Partsexpress.com has power supplies 12vdc up to 40 amps (50 amp peak):
http://www.partsexpress.com/webpage....ctGroup_ID=427
Old Jan 14, 2006 | 11:12 PM
is 50 amps enough to power the amp???
Old Jan 15, 2006 | 06:08 AM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
look at the fuse rating and you tell us
Old Jan 15, 2006 | 07:32 AM
SurraTT's Avatar
HR Swap Pioneer
i just hacked a cpu power supply, worked fine
Old Jan 15, 2006 | 07:48 AM
buttonhook's Avatar
DITTO!!!!!!!!!!!!!!!!!!!
Old Jan 15, 2006 | 07:57 AM
nismos14's Avatar
§è~® f®ÈÄk
So what does one use for the remote wire in this type of setup?
Old Jan 15, 2006 | 08:44 AM
djfrestyl's Avatar
Suspension Yoda
Lightswitch
No need for a remote turn on, just use the same power feed you have from your ac-dc converter, or computer power supply.
Old Jan 15, 2006 | 08:52 AM
whlimi's Avatar
Can someone post a link to a "how to" for the hacked cpu power supply if such a link exists?
Old Jan 15, 2006 | 09:16 AM
CreativeDesignz's Avatar
ill post one if u want ur house to burn down in the process
Old Jan 15, 2006 | 09:32 AM
1996blackmax's Avatar
This posts brings back memories for me . I did this when I was in high school (maybe 10th grade). We had a laundry room in the back yard (attached to another small house/garage thing back there). My friend's brother had a "burned out" Alpine he was going to throw out. I then ended up fixing it by using strands of speaker wire and solder on the burned part of the circuit board. I used that, a small amp and two 6x9's in there. Was not very loud but worked . Oh I also used my dad's power converter .
Old Jan 15, 2006 | 10:43 AM
so basically take the plug from a cpu and wire it to the amp?
Old Jan 15, 2006 | 10:48 AM
whlimi's Avatar
How is it that other are using the cpu power supply without a problem?
Old Jan 15, 2006 | 10:49 AM
AscendantMax's Avatar
oh man, i'm just seeing a lot of fire accidents waiting to happen...
djfrestyl's Avatar
Suspension Yoda
Not that easy. Gotta know which wires are hot, gound, etc.
Old Jan 15, 2006 | 12:26 PM
haha i think the others did it alright, i dunno i would rather not risk burning my house down just to power a sub in my room lol.
Old Jan 15, 2006 | 01:00 PM
505max94se's Avatar
Since my car is out of commission, I've hooked up my whole active setup (except sub) in my house. It's running off of an IOTA 90 amp power supply and an optima red top.
Old Jan 15, 2006 | 05:11 PM
yes...i know this. i have a voltmeter for that. But am i thinking about the right thing?? Its the black plug which plugs from my cpu to the outlet?
Old Jan 15, 2006 | 06:21 PM
nismos14's Avatar
§è~® f®ÈÄk
You'll probably blow your houses fuse box if you plug that black plug into the amp. Don't be crazy.
Old Jan 15, 2006 | 06:57 PM
OK...i'll wait for a write-up or sumthin cuz i'm not sure what cpu power supply is being talked about.
Old Jan 15, 2006 | 08:58 PM
whlimi's Avatar
Could we use a battery charger hooked up to like an optima deep cycle to run a system? Or will the charger have a tough time maintaining the battery?
Old Jan 15, 2006 | 09:03 PM
Digital's Avatar
VIP
lmaoooooooo me 2
Old Jan 15, 2006 | 10:48 PM
just buy a friggin house sub from best buy for 150 bux
Old Jan 15, 2006 | 10:54 PM
dblair's Avatar
I have also hacked PC power supply for similar projects. However, if you use a PC power supply, make sure you check the supply's power ratings carefully, don't just look at the total wattage. An PC power supply has a 3.3V, a 5V and a 12V rail...yellow wires being the +12V. The rating for the 12 volt rail of a 300W power supply may be as little as 12amps (or less). Also, computer power supplies often require a minimum load of an amp or two on the 5V rail in order to operate.
Old Jan 16, 2006 | 05:24 PM
91maximase's Avatar
couldnt you just wire it to a home reciever?
Old Jan 16, 2006 | 06:41 PM
a lot of home recievers aren't stable below 8 ohms (which is the nominal for a lot of home speakers)
Old Jan 17, 2006 | 05:33 AM
buttonhook's Avatar
the black wires are ground and the yellow wires are 12volt(in general)
Old Jan 17, 2006 | 10:58 AM
Sharp's Avatar
yeah my Acoustic Reference massive studio speakers are only 8 ohms...but you would think they would be less considering the power...
Old Jan 17, 2006 | 11:29 AM
KyMan's Avatar
My Monitor Audio towers are 6-ohms (yeah, that sux, but the speakers are absolutely amazing). Finding a receiver that will run them without frying is a little more difficult.
nismos14's Avatar
§è~® f®ÈÄk
Well its more about the amp's output as far as home audio goes anyways.
Old Jan 17, 2006 | 01:38 PM
505max94se's Avatar
It shouldn't be that hard to find an amp that will go down to 4 ohms and run off of 110v. Just look for a high current pro audio amp....
Maximan190
Dec 16, 2015 06:01 AM
popdedop
Sep 11, 2015 11:17 AM
maximusrising
Sep 4, 2015 06:31 PM
trungg86
Sep 4, 2015 04:58 AM
