Serious Help Needed Quick...PLEASE!
Old Jan 16, 2006 | 09:18 PM
Max_N_Action's Avatar
i just tried installing my jvc dvd 5100 deck. when i spliced the harnesses together i accidently cars power remote antenna(the black thing one with the 2 prongs) to one of the bare wires on the harness and it sparked for a sec. im retarded and i forgot the tape that one up and it happened to touch it. so now neither the aftermarket or the bose radio will work. im gonna lose it. i cant beleive this happened. do you think i burnt out the power antenna and now neither deck will turn on. if so how do i fix this. or is there jsut an antenna. please help me. ahhhhhhhhhh!
Old Jan 16, 2006 | 09:23 PM
nismos14's Avatar
§è~® f®ÈÄk
Probably just the fuse. Check the fuse on the back of the radios, and the audio/acc fuse in the fuse box and under the hood. If not check as many of the other fuses as you can.
Old Jan 16, 2006 | 09:39 PM
omg dude i love you.... i fixed it..... iwas so scared..... mite as well ask another qquestion before i tackle this install again. since i have to ground 2 things, the actually ground then the wire to the parking break, can i just connect them 2gether then ground them? it makes sense to me..... is that a bad idea?
Old Jan 16, 2006 | 09:42 PM
filtor1's Avatar
What 2 things are you grounding?
Old Jan 16, 2006 | 09:47 PM
there both on the jvc deck.....ones the black ground and one says parking break
Old Jan 16, 2006 | 09:56 PM
filtor1's Avatar
That would be fine. I do recommend them both terminating at the final grounding point though.
Old Jan 16, 2006 | 10:29 PM
ok cool thanks.... im gonna attempt this install again when its not 2 in the morning
Old Jan 17, 2006 | 06:33 AM
nismos14's Avatar
§è~® f®ÈÄk
Probably the best idea yet!
Old Jan 17, 2006 | 10:26 AM
filtor1's Avatar
Sounds like a plan. Keep us updated.
Old Jan 17, 2006 | 01:29 PM
ok so i install the deck and the bose sounds alright, but does get as loud as before. the sub however sounds a lot better since im using it off the headunit and not the line out converter. however, now i have a realy annoying problem. i spliced the rcas and pluged them into the rca outputs of the deck. now, when i ever i do certain things like, change the radio station, change some of the presents or turn the car on and off, i got a popping noise through speakers. ino it have something to do with the bose because if i unplug the spliced rcas and just use the subs, they dont pop. what would i have done wrong. its sooooooo annoying.
Old Jan 17, 2006 | 01:49 PM
nismos14's Avatar
§è~® f®ÈÄk
Thats the bose speakers turning on and off.... sorry to say theres no really easy way to get it to stop.
Old Jan 17, 2006 | 01:52 PM
wow thats horrible.... man im gettin rid of the bose asap
Old Jan 17, 2006 | 02:41 PM
nismos14's Avatar
§è~® f®ÈÄk
to that idea.
nismos14's Avatar
§è~® f®ÈÄk
to that idea.
Old Jan 19, 2006 | 11:32 AM
anyone else have an opinion about the popping noise. someone else said it souldnt be doing that. wat could i have done wrong...
Old Jan 20, 2006 | 12:26 PM
bump......
smplyamzng
Dec 13, 2015 01:19 PM
boomerbrian
Nov 8, 2015 05:10 PM
TonyJr
Aug 20, 2015 12:14 AM
wingsfan24
Aug 15, 2015 07:35 PM
