power relay necessary?
Old Jan 31, 2006 | 04:53 PM
NismoMax80's Avatar
SuPeRmOd
I plan to tap my bose system just before the bose amp to add an amp/sub. Using a Hi-Lo for the signal and the oem remote for my amp remote (blue wire).
It was suggested that I use a relay when tapping the remote. Can anyone clue me into what I need? I was just going to cut and splice with a butt connector (1 in 2 out).
for the Hi-Lo should I just tap it from the inputs at the amp, or splice before?
Looking at ebay for: 12ft 4awg wire, 4awg connectors, 4-4awg gold terminals, hi-lo convertor, 100 amp circuit breaker, and rca cables. I prefer to deal with orgers when possible, feel free to email me. Also interested in lightweight sound deadener.
thanks guys.
Old Jan 31, 2006 | 06:44 PM
djfrestyl's Avatar
Suspension Yoda
I know that in a 5th gen it's suggested to add a relay for the remote turn on. I don't have the wiring diagram off hand though.
I don't know how far you are from Edison, but I suggest making the trip up to see Don for your system. It will be well worth the trip and you know the work will be nothing short of top-notch.
Old Jan 31, 2006 | 09:30 PM
Pearl96Max's Avatar
I tend to get a bit irritable
I could always pass it off to one of my employees.
Old Jan 31, 2006 | 09:32 PM
Pearl96Max's Avatar
When using a factory turn on, I would recommend it.
Standard SPDT relay..
87 = Constant 12V
86 = Ground
85 = remote IN from radio
30 = remote OUT to amp(s)
Old Feb 1, 2006 | 07:13 AM
djfrestyl's Avatar
Suspension Yoda
87 = Constant 12V
86 = Ground
That chart is your b!tch. I don't mind helping, just let me know.
woo woo 1900 posts.
Old Feb 1, 2006 | 08:54 AM
NismoMax80's Avatar
SuPeRmOd
thanks, that clears it up for me. I assume using my distribution block for my amp will be safe to use for the relay's constant 12V?
Old Feb 1, 2006 | 08:59 AM
Pearl96Max's Avatar
woo woo 1900 posts.
What chart? That paper I gave you? That was for YOU my friend. I know my relays.
Pearl96Max's Avatar
Yessir thatll be fine
Old Feb 1, 2006 | 09:06 AM
NismoMax80's Avatar
SuPeRmOd
now I just have to order on ebay
Old Feb 1, 2006 | 09:15 AM
Pearl96Max's Avatar
a relay?? Just go to the shack
Old Feb 1, 2006 | 09:39 AM
NismoMax80's Avatar
SuPeRmOd
actually I found a relay I never used, I need the other items in post 1.
Old Feb 1, 2006 | 10:15 AM
Pearl96Max's Avatar
No need for a LOC either though.
Old Feb 1, 2006 | 11:08 AM
djfrestyl's Avatar
Suspension Yoda
If you relay will be in your trunk, or wherever your dist block will be.
Old Feb 1, 2006 | 11:09 AM
djfrestyl's Avatar
Suspension Yoda
New acronym.
FOS.
full of ****. Describes you perfectly, my friend.
Old Feb 1, 2006 | 12:19 PM
Pearl96Max's Avatar
New acronym.
FOS.
Care to back that up sir?
Old Feb 1, 2006 | 12:33 PM
djfrestyl's Avatar
Suspension Yoda
Later. out the door for class at 4:30.
You refer to the sheet, just admit it
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
zmcneely13
Sep 26, 2015 02:26 PM
