amp is in safe mode.
Old Feb 13, 2006 | 10:14 AM
hybridioN's Avatar
all teh single ladiez
long story short. i took a corner too fast, my box wasn't fastened down that well. some wires came out, and some bent. i got everything back into place and what not. now the lights on my amp are flashing and nothing is working.
amp is a JBL CS Series 580 watt.
any help would be appreciated.
Old Feb 13, 2006 | 11:10 AM
AscendantMax's Avatar
go back and double check all the wiring to see they're in the right place/secured. wouldn't hurt to check again.
Old Feb 13, 2006 | 01:43 PM
nismos14's Avatar
§è~® f®ÈÄk
I agree, also check the wiring in the box, and to the head unit.
Old Feb 13, 2006 | 06:24 PM
hybridioN's Avatar
all the wires are correct, fuses aren't blown, amp is getting power.
Old Feb 13, 2006 | 06:36 PM
filtor1's Avatar
You need a new amp if that is the case.
Old Feb 13, 2006 | 08:13 PM
nismos14's Avatar
§è~® f®ÈÄk
Did you also check inside the sub box for loose wires?
Old Feb 13, 2006 | 09:25 PM
DcMaN's Avatar
unplug the wire going to the subs and see what happens. Turn the car Off and then back on. If it is still in protect mode you will need to have it serviced. Also check to make sure the ground is still secure.
Old Feb 14, 2006 | 04:56 AM
hybridioN's Avatar
the amp power LEDs are flashing. after taking a look at the JBL manual online it says that the cause is the voltage is less than 9V on the BATT+ connection. my alternator isn't the problem, so i figure it has to be the amp. this audio place here in town is going to take a look at it for me this afternoon.
Old Feb 14, 2006 | 11:07 AM
so just take a DMM and measure what the voltage is at the end of the power wire. save you the time and money from getting a shop to look at it.
Old Feb 14, 2006 | 11:21 AM
hybridioN's Avatar
tested it. it's getting power.
Old Feb 14, 2006 | 11:24 AM
how much power?
Old Feb 14, 2006 | 01:14 PM
hybridioN's Avatar
took it over to the audio place. it's blown. they would of swapped out a the same one for me, no charge, but my idiot friend had to scratch it and **** when he had it. oh well, i'm going to spend a little and get a bigger amp.
thanks for all the help.
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Andy29
Sep 29, 2015 05:32 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
