Oddyssey Battery ?'s
Old Feb 27, 2006 | 02:38 PM
Dubbya's Avatar
VK56 Inside
Ive been looking into doing a lighter battery set up for my car. I see that some people are using the PC680MJ, but the cranking amps are low. I ran across this other battery and wanted to know if there would be any issues anyone can think of in using it.
http://www.motorcyclebatteriesusa.co...asp?battery=37
Old Feb 27, 2006 | 02:47 PM
Kevlo911's Avatar
Kevlo for President
Sweet link buddy...
Old Feb 27, 2006 | 02:48 PM
Dubbya's Avatar
VK56 Inside
Old Feb 27, 2006 | 10:31 PM
1FSTMX
Would you use the battery full time, or just at the track? There are much better ways of saving weight.
Old Feb 28, 2006 | 07:03 PM
z32drifter's Avatar
Well if you need a battery, you can save some weight on the front of the car with the PC680MJT. I'm running one in my Z. Weight savings of 24lbs over the Optima red top that was in the car. No problems as long as the car does not sit for 3+ weeks with out running. Warning this is not a battery for sitting around running the system, you will drain it before you realize. The reserve time is very limited.
Old Mar 1, 2006 | 07:06 AM
Dubbya's Avatar
VK56 Inside
Thanks for the info. I decided to go with a Red Top.
Old Mar 14, 2006 | 08:14 PM
maxunknown's Avatar
battery
optima only 1st & best
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
markevans999
Sep 10, 2015 04:29 PM
