Finally started on audio in the 6th gen
Old Mar 4, 2006 | 08:55 PM
AscendantMax's Avatar
here's a pic of the test fit with the amps and sub my friend and I did today. pretty much will go across the width of the trunk, and the two arcs on either side. still needs some minor adjustments, carpet, etc. we're gonna snap some more (and better) pics later. what you guys think?
still debating if i want to invert the sub like in the pic, or mount it 'normally'.
Old Mar 4, 2006 | 08:57 PM
slickrick's Avatar
thats tight...invert it and no need for a grille!
Old Mar 4, 2006 | 09:00 PM
MannyNJ2k2max's Avatar
x2 i likey!! Thats gonna look hotness!
Old Mar 4, 2006 | 09:03 PM
only thing is, i don't know where/how i'm going to run the wire to the sub while maintaining a 'clean' look if i invert it.
Old Mar 4, 2006 | 09:09 PM
slickrick's Avatar
es imposible...
Old Mar 4, 2006 | 09:15 PM
Thats why you go with a nice 8 or 10 gauge for speaker wire. Go to a local shop and just feel'm up to see which has the flexibility and clean look you like. Then a tight as s hole in the top of it, siliconed in. Is the area above the sub ALL part of the enclosure?
Old Mar 4, 2006 | 09:18 PM
nuh uh, you see the top pencil line on the two sides? that's the top edge of the box.
yeah, think i'll visit some shops aroud here and see what i can use for speaker wires. more strands = more flexibility correct?
Old Mar 4, 2006 | 09:24 PM
1996blackmax's Avatar
Looking very nice .
Old Mar 4, 2006 | 09:33 PM
thanks. we're pretty eager to finish it up and put it in the trunk.
i just gotta run some lines...i hate running lines
Old Mar 4, 2006 | 09:58 PM
LeX's Avatar
LeX
Nissan by Nature
I like subs mounted normally, never been an inverted fan. Looks good
Old Mar 4, 2006 | 10:05 PM
swowlinc's Avatar
1993 SE
Nice. If you want a clean look you shouldnt invert them. If you want to show off however...flip it over.
Old Mar 4, 2006 | 10:07 PM
2 Da Max's Avatar
looks good, but if the sub is mounted invertedly, you might regret it later on when you may need trunk space.
btw how does the sound differ when mounted in that position compared to it mounted normally?
Old Mar 4, 2006 | 10:23 PM
swowlinc's Avatar
1993 SE
I believe you get a good bit more bass like that. Might be in my head though but I think it sounds better inverted.
Old Mar 4, 2006 | 11:07 PM
thanks for the comments
but nah, no difference in output whether inverted or mounted normally.
Old Mar 4, 2006 | 11:19 PM
slickrick's Avatar
tisk tisk you know better...you have more internal airspace with it inverted which=more low end.
Old Mar 4, 2006 | 11:46 PM
BBOYSTEVIE's Avatar
Back from Hibernation
That's gonna look really good either way you mount it. Are you going to have to take out the box out to access the amps?
Old Mar 5, 2006 | 12:08 AM
haha yeah, but you know what i meant
for one of the amps, i can access the crossovers, etc on top. but for the other amp, getting to the amp's controls might be a bit difficult. i think i'll just tweak it before mounting it. i just need to lower the back seats to get to them.
Old Mar 5, 2006 | 07:41 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Looks Great Gordon, nice work and keep us posted..
Old Mar 5, 2006 | 07:47 AM
nismos14's Avatar
§è~® f®ÈÄk
Very nice looking!! Great job!
Old Mar 5, 2006 | 08:14 AM
thanks
although more credit should go to my friend.
Don, those two foam strippings of foam behind the 1500, can i remove that? or did you put that there for a reason? it's kinda of a tight squeeze to fit it into its mount.
Old Mar 5, 2006 | 10:10 AM
nismos14's Avatar
§è~® f®ÈÄk
I'm guessing the foam was there to allow the fan to breathe underneath the amp when mounted. I would suggest you take them off, but ensure that you make cutouts on the inner board so the amp fans can pull in outside cooler air to cool things off.
Old Mar 5, 2006 | 10:23 AM
but there's no fan inside the 1500.
i want to take them off, but i was curious why Don put them there in the first place.
Old Mar 5, 2006 | 11:04 AM
02maxxxSE's Avatar
Very nice setup, man. Great job.
Old Mar 5, 2006 | 11:54 AM
nismos14's Avatar
§è~® f®ÈÄk
There isn't??? 1 ohm stable and no fan?? Interesting, anyways I would suggest just removing them, my next guess is its since he had all his amps mounted one in front of the other in the old setup \\\ <-- like that
Old Mar 5, 2006 | 01:25 PM
nope, no fan. and the amp gets medium warm at best even after hours of playing...
yeah, if i remove it, i can slide it into its mount without risking scratching the logo.
Old Mar 5, 2006 | 02:21 PM
djfrestyl's Avatar
Suspension Yoda
Looks good Gordon.
Old Mar 5, 2006 | 03:16 PM
Pearl96Max's Avatar
thanks
You can take it off, that was there when they were in my Accord "leaning" on one another...
Old Mar 5, 2006 | 03:24 PM
alright, sounds good.
Old Mar 5, 2006 | 04:01 PM
mendon99's Avatar
tastey wheat
looks great. wish i had the proper tools to do such an install
Old Mar 5, 2006 | 06:20 PM
thanks. we're going to try to get the box done this week.
Old Mar 7, 2006 | 08:00 PM
little update. the panel is now carpeted to match the trunk. a large slot is cut above the sub cutout to hopefully help with the bass being vented into the cabin since the baffle might block the output. the baffle is designed to fit the width, height, and contour of the trunk.
Old Mar 7, 2006 | 08:01 PM
slickrick's Avatar
is that a ghetto port???????????
Old Mar 7, 2006 | 08:03 PM
yes Rich, it's a ghetto port...
Old Mar 7, 2006 | 08:09 PM
slickrick's Avatar
I knew it!
Old Mar 7, 2006 | 08:10 PM
djfrestyl's Avatar
Suspension Yoda
So fresh and so clean clean...
Looks good Gordon get it installed man!
Old Mar 7, 2006 | 08:16 PM
should have everything installed this friday
Old Mar 7, 2006 | 08:17 PM
slickrick's Avatar
I want a full report...GL waiting 4 the AA's though.
Old Mar 7, 2006 | 08:48 PM
i'm going to call them since they suck at replying to emails.
Old Mar 7, 2006 | 08:54 PM
Pearl96Max's Avatar
And this is a compnay you WANT to deal with?
Old Mar 7, 2006 | 08:57 PM
slickrick's Avatar
eh it is a small company I told him to call 4 a good response. Pioneer has never responded 2 my emails about my TV I emailed them awhile ago about, but I don't hate on pioneer for it.
