Stock Bose Sub Cutting Out
Old Mar 5, 2006 | 07:20 PM
jenk01SE's Avatar
My stock Bose sub on my 5th gen is cutting out at medium-to-high volume and will only come back on if the volume is reduced to medium-low. This problem started about 6 months ago and I have not changed the bass settings or the type of music I listen to. I have taken the amp and sub assembly apart and there are no obvious component failures or solder anomalies. Does anyone have a solution to this problem?
Please don't clog the replies with "Ditch the Bose" or "Blose Sux". I am looking for legitimate answers only. Thanks.
Old Mar 5, 2006 | 07:56 PM
djfrestyl's Avatar
Suspension Yoda
This is a common problem with Bose and can only be remedied by a replacement unit.
That being said, If you're out of warranty, your money will be better spent with an aftermarket head unit.
Old Mar 6, 2006 | 07:40 PM
jenk01SE's Avatar
Definitely out of warranty...~88k miles. So this problem is resident in the HU, not the equipment under the parcel shelf? Also, what is the best choice for a new HU and do I essentially have to sh!tcan the equipment under the parcel shelf? Thanks for your help.
Old Mar 7, 2006 | 05:57 AM
djfrestyl's Avatar
Suspension Yoda
Correct, although some people have experienced problems with the Bose sub itself. Do you have a local friend that you can swap your sub out with to see if it is the sub?
Prior to spending money on a HU it would be best to ensure which piece of equipment is the culprity
Old Mar 8, 2006 | 10:09 AM
jenk01SE's Avatar
Thanks. What is the currently accepted replacement HUs?
Old Mar 8, 2006 | 11:15 AM
djfrestyl's Avatar
Suspension Yoda
Prior to spending any money I suggest finding out which piece of equipment is faulty.
That being said, the masses here seem to prefer Eclipse Head Units, for their sound quality, craftsmanship, and superior warranty.
James92SE
142
Jan 2, 2024 09:23 AM
9aj9
Apr 5, 2020 12:11 AM
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
Maxima Pride '07
Sep 12, 2015 07:29 AM
