fuse keeps blowing
Old Mar 8, 2006 | 06:34 PM
maxcooldc's Avatar
fuse keeps blowing
my speakers have stopped working since sunday (bose head unit works well lights up and plays cd but no sound) i checked the fuse box under steering and found the 15 Amp fuse in the "bose" slot had blown. After i replaced the fuse my speakers worked for about 1 second and stopped working (fuse had blown again) each time i replace the fuse and turn on the headunit the fuse blows.
i haven't done any electrical work on the car and I haven't anything out of the usual.
has anybody every had this problem? and how did you solve it?
does anybody have any suggestions on how to solve this problem
Old Mar 8, 2006 | 06:51 PM
djfrestyl's Avatar
Suspension Yoda
Time to diagnose what is blowing the fuse.
Pull out your Blose HU and disconnect it. Put in a good fuse. Does it pop?
Old Mar 8, 2006 | 08:21 PM
kpr10is's Avatar
Worst case scenario youd have to get yourself a multimeter and figure out exactly what is grounding out, whether its one of the power wires going to the deck/one of the bose amps, etc. Weird problem though if you are 100% stock.
Old Mar 9, 2006 | 06:07 AM
clive's Avatar
100% chingon
It sounds like one of your Bose amps has had a capacitor failure and probably blown the output transistors. Since the rears are the easiest to get to, I'd start by disconnecting the power line to both of your rear units, replace the fuse and try the system. If the fuse blows, reconnect the rear units, take the front door panels off and disconnect the power to both fronts, replace the fuse, test.
When you localise it to front/rear, test each speaker individually.
If you have had the output pair in an amp fail, the problem is finding proper replacements, the market is flooded with counterfeit Chinese power devices that don't work properly. In that case I would look for getting a spare complete amp or a pair, from an org member or EBay. Easier fix.
Old Mar 9, 2006 | 10:03 AM
maxcooldc's Avatar
thanks i think i will do that this afternoon when i get home
Old Mar 9, 2006 | 06:03 PM
djfrestyl's Avatar
Suspension Yoda
No problem, keep us posted.
Good luck
tarun900
19
Dec 20, 2021 06:57 PM
leatherneck
Sep 30, 2015 09:16 PM
Noela
Sep 26, 2015 08:22 AM
