wha u guys think?
wha u guys think?
I got a 7in Touch Screen
2- 10" Evs
2-10"Zeus 400
2 Bullet Tweeters
2-12"Audiobahns
A 1.2 Farad Cap
745 Watt RMS 2 Channel Amp
Memphis 75 watt RMS 2 Channel Amp
Kenwood 800 Peak Watt 2 Channel Amp...
Stock Interior Speakers all the way!!!!!
2- 10" Evs
2-10"Zeus 400
2 Bullet Tweeters
2-12"Audiobahns
A 1.2 Farad Cap
2- 10" Evs
2-10"Zeus 400
2 Bullet Tweeters
2-12"Audiobahns
A 1.2 Farad Cap
2- 10" Evs
2-10"Zeus 400
2 Bullet Tweeters
2-12"Audiobahns
A 1.2 Farad Cap
you're putting 6 subs into one car? hmm...i say get ready to replace an alternator or two, pick up about 2 backup batteries and then you can do it. Also you may have to change your suspensiopn in the back because i would think you rear end would sag LIKE HELL if someone were to sit down int he back due to all the weight...
That just seems like a big waste. Juan is on the ball, definately should have bought 4 speakers and stayed with 2 subs. 2 subs 1 set coax's 1 set comps, get rid of the bullet tweeter. Get rid of the cap, get an aftermarket HU. If 2 subs aren't enough for you your doing something wrong.
well suspension is not my issue already done that no saggin issue...a far as the mids the zeus handle that..my stock speakers are barely heard over my ev's n zeus..next is some eclipse componet speakers...just waitin on that for now...my batt is holding up gr8 because the ev's and zeus do not have that much draw bc they r mid/high speakers only my 12's r killing the alt.....
So you're letting subs that are in your trunk do your midbass duty?
. The point of stock speakers or speakers in that location is to have a well rounded sound, and to have a SOUNDSTAGE. Right now you have absolutely no staging. When you get those eclipse's you'll be doing alot better.
You're wasting all that space trying to use SUBwoofers for mids and highs. SUBwoofers are built to play the range that a midbass can't. Submidbass frequencies. Your defeating the purpose completely. Honestly your ev's and zeus's would get blown away in "mids and highs" by any real quality mid's and tweets.
Did you get some guidance when choosing this system? Worse that Avi's!
. The point of stock speakers or speakers in that location is to have a well rounded sound, and to have a SOUNDSTAGE. Right now you have absolutely no staging. When you get those eclipse's you'll be doing alot better. You're wasting all that space trying to use SUBwoofers for mids and highs. SUBwoofers are built to play the range that a midbass can't. Submidbass frequencies. Your defeating the purpose completely. Honestly your ev's and zeus's would get blown away in "mids and highs" by any real quality mid's and tweets.
How I have it setup is an aquired taste...Not everyone likes how it sounds n stuff...It loud and can be heard several blocks away but its not for every1....
Doesnt look bad...
Doesnt look bad...
workin on it..i got a lil more on my mind these days....Going to IRAQ kinda takes u mind up alot...I need more pix just got to clean it up a lil the trunk it self is nothing big just a box with 2 12's amps r mounted to the back seat with the cap need to redo the wiring a lil to much visible.....
I would throw those Eclipse speakers up front. Get rid of the bullet tweeters in the back. If all those 10's are infinite baffle subs, I would probably leave them as they are (if the rear deck is not reinforced sufficiently I would tackle this, and try to seal up the trunk as best I could). Maybe make all four subs from the same company, and same models. At this point I would have no need for the 12's, and so I would have a ton of trunk space left. Just some advice, is all.
I wish you good luck over in Iraq, and thank you for your service. Stay safe.
like i stated its an aquired taste not for every1...
Originally Posted by Pearl96Max
I guess thats something Ill never aquire.
i have heard a quality setup right now not what i want....when i get home i going to get rid of my max and get a 540 then I will go your guys way with all the interior setup...my setup now is quality sounds good no distortion clear as a whistle...Its also diff bc none of you guys r doing anyting like it...SO step out u lil box and think different do something u wouldnt do...u will surprise u self u live once...I like my stuff if you dont O well will prob never see you ne way...
Wasnt the name of this thread "Wha u guys think?" i dont get it. Why start a thread called "wha u guys think" and dont like it when we tell you what we think? Why not just name the thread "I dont care what you think" and move on with your life. Jeez...getting all defensive and upset ^^^^ there. Maybe you shouldnt post stuff you're not gonan hold yourself responisble for posting. You sound like a kid on that last statement...think about it, like anyone really cares
P.S. I dont mean to sound offensive but that last comment just sounded so childish...my bad in advance.
You may like how it sounds, but honestly there are 6.5's that would **** on the setup you have and you would be more than happy with that.
I didn't know "bad" was an acquired taste.
I don't eat **** but maybe if I eat enough of it I'll acquire a taste for it.
But hey, if YOU like it, and your ears can handle it, and you're NOT missing midbass, kudos to you, we'll be waiting when you get your 540.
Max139617
Sep 6, 2015 06:02 PM
