sub wiring ?
Old Mar 18, 2006 | 10:48 PM
YellowOne's Avatar
sub wiring ?
just wondering if it's possible to wire a dual 2 ohm and a dual 4 ohm sub together to a mono amp?
Old Mar 19, 2006 | 06:50 AM
filtor1's Avatar
Short answer, No.
Why would you try something like that?
Old Mar 19, 2006 | 07:16 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Why isnt it possible Chris?
Old Mar 19, 2006 | 07:47 AM
adampit's Avatar
You can use this to figure it out
http://www.the12volt.com/caraudio/boxcalcs.asp#rec
Old Mar 19, 2006 | 07:50 AM
BBOYSTEVIE's Avatar
Back from Hibernation
I guess it's possible. Different speakers would see different amounts of power though, right Don?
Old Mar 19, 2006 | 08:32 AM
Pearl96Max's Avatar
Technically speaking its possible. Although if its a pair of identical speaker just with different configuration, I dont see it being a problem. It certainly has been done beofre to achieve a certain load in multi driver setups.
Old Mar 19, 2006 | 08:33 AM
YellowOne's Avatar
so not possible?
Old Mar 19, 2006 | 08:34 AM
YellowOne's Avatar
subs i've have are both rockford he2, again one is dual 2ohm the other is dual 4ohm, 400rms, 800max.
Old Mar 19, 2006 | 12:10 PM
Majestic303's Avatar
Pearl is correct, you'd get some weird ohmload of something like 1.33~ ohms by wiring them in parallel, which if your mono amp was 1ohm stable it would technically work, but your amp would get smokin' hot if it were HC.
Old Mar 19, 2006 | 04:07 PM
filtor1's Avatar
This is where I was going Don. I would never recommend someone doing this. Between the odd ohm loads on the amp and continuously variable impedence fluxuation, I would just stay away.
Old Mar 19, 2006 | 05:01 PM
Pearl96Max's Avatar
Thats where me and you differ.
Old Mar 19, 2006 | 05:03 PM
slickrick's Avatar
I would pass personally on 2 different DVC coil configurations because t/s specs change on some subs with different coil configs...however one can argue throw t/s specs out the window when subwoofers are broken in for awhile.
Old Mar 19, 2006 | 05:21 PM
Pearl96Max's Avatar
Im not saying he should do it, just rather than it can be done with little or no adverse affects.
Old Mar 19, 2006 | 05:46 PM
slickrick's Avatar
word up.
Old Mar 20, 2006 | 07:09 AM
nismos14's Avatar
§è~® f®ÈÄk
Whats the amp stable to? I assume 1 ohm if thats the case wire the dual two ohm sub to 4 ohms (in series) then take each coil of the dual 4 ohm sub and wire them all in parallel to the amp. The dual 4ohm sub will be louder however because it will recieve more double the power from the amp based on having two 4 ohm coils as opposed to the single 4ohm config of the dual 2ohm sub wired in series.
In my first car I had a 2 channel amp that I powered 3 subs off of. One solo baric 15, with two pioneer free airs mounted in the pass through of my backseat into the cabin. The free airs wired to 8 ohms on one channel and the sub wired 4 ohm to the other. It worked out perfectly. The 8's got about 1/2 the power of the 15 and it blended in very well. I used outboard xovers to cut off frequencies on the 8's and an additional one on the 15, it worked out very well.
Old Mar 21, 2006 | 11:34 AM
tcaughey's Avatar
crazy, it's possible if the amp is 1 OHM stable right? I think, o well, what do I know.
Old Mar 21, 2006 | 11:41 AM
nismos14's Avatar
§è~® f®ÈÄk
Ya just one speaker will be getting more power than the other based on the wiring config.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
