Computer Install problem #1A
Ok .. I have the inverter and UPS deal all ready... but the inverter needs to be connected to a circuit rated for 25amps or more and it needs to be SWITCHED power so when I kill the ignition the power to the inverter dies. Where am I going to find this power lead?
Thanks in advance (many more problems to come, I anticipate)
later,
/aac
later,
/aac
I have my inverter wired straight to the battery, plus to plus and ground to negative. I threw a 30 amp inline fuse in there and also a relay. The relay taps into the cig lighter for the ignition kill.
Chris
Chris
Chris
Chris
I am assuming I am going to have hot running from battery to relay. Then an accessory wire (like lighter) into another post on relay. Then a "switched hot" running out of relay and to inverter. I am assuming the inline 30A fuse is on the wire that runs from the battery to the relay?
Thanks in advance for your help,
/aac
Lakersallday24
Nov 7, 2024 07:31 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
kirkhilles
Aug 8, 2015 10:53 AM
yat70458
Aug 3, 2015 01:16 PM
