all i hear is bass
all i hear is bass
i got an alpine SWR-1242D sub and a alpine mono MRD-M605 amp and stock speakers...this system pretty much sucks right now since all i hear is bass and rattling. i spend a good amount of money on it since i bought it awhile ago but right now its making me upset since the sound sucks. the bass is overwhelming
what speakers/componets should i buy? to tell you the truth im a super noob in audio and i dont even know whats the difference between components/speakers or how many i need? or if i need a seperate amp for them? i know i havbe two speakers in the rear and two in the front wow
First of all, your car looks awesome.
Now on to the good stuff. Anyone can recommend something too you, but they would first need a budget and what type of music you listen too. This will allow us to make better suggestions for your specific application.
As far as the rattling, check out the deadener sticky at the top of the main Audio Forum page. You will find it usefull.
my budget is not too big maybe 200-350? i listen to everything from sublime to tupac so a mix of a lot of things really. i was thinking going with alpine type r speakers?
Originally Posted by slickrick
no no...what you SHOULD do is hop on the Rainbow Soundlines GD before it ends very soon. they are in your budget and will OWN those Alpine's.
Originally Posted by roll4life
that sounds like a good idea but how soon does the GD end? i was planning on buying new stuff in a month or so thanks for the offer though
Considering your budget, I would go with the SLC265's up front and the kx 165's in the rear doors. I recently installed this exact setup and was very impressed. With the GD, you should stay within your budget as well.
i still have some questions guys
do i need to buy anything except an amp and speakers..such as wiring or any kind of little boxes with the flashing lights? i honestly don't know what they are called.
i installed my amp and sub myself and it was fairly easy. installing speakers is much harder or same level?
do i need to know anything else? im planning to do the install myself so any tips would be good
WHat you need depends on if you are using the stock HU or not.
So far you are going to need speaker wire (about 40ft will do), power and ground for the amps, a remote wire (length depends on amp placement), the amp, and speakers.
If you are using the stock HU, you will need a Line Out Converter (LOC), this will not be needed with an aftermarket HU.
my hu isnt stock
so basically an amp wiring kit will do again? i used a rockford fosgate 4 gauge wiring kit that i got from best buy. it was over 100 bucks. i was thinking of getting like a 12-14 gauge wiring kit that comes with remote,ground and power wires. i hope that will be cheaper. any fabricating needed when installing speakers?
my hu isnt stock
Originally Posted by BRINKLEY
ouchie, $100 bucks for a wiring kit? geeeeeeeez. I hope that is a typo.
tarun900
19
12-20-2021 06:57 PM
AaronL
08-08-2020 10:31 AM
DC_Juggernaut
09-28-2015 04:07 PM
