Battery draining overnight
Old Apr 2, 2006 | 09:19 PM
WhiteMaxima9600's Avatar
A friend of mine has a couple of jl 10's in his truck he bought from another friend. His amp which is a jbl 180.2 keeps draining the battery overnight.. I checked his wiring and everything is exactly like mine. I have never had this problem... What exactly should we check? Think the amp is just bad or has a ground problem??
Thanks again
Old Apr 2, 2006 | 11:01 PM
AscendantMax's Avatar
you guys didn't connect the remote turn on to a constant 12v source did you...? sounds like the amp isn't turning off.
Old Apr 3, 2006 | 09:43 AM
No the amp is connected to the remote turn-on lead coming from the hu... Also the red light on the amp is turning off with the switch and there's no power to the amp... The amp is gotta be bad or something
Old Apr 3, 2006 | 11:14 AM
03SE2HEAR's Avatar
Disconnect the amp completely tonight and that should tell you. There may be a short in the power supply causing this even though the power light is off.
Old Apr 3, 2006 | 08:55 PM
yeah when he took out the fuse in the power wire it was fine the next day... just could not figure out why the amp was drawing power when nothing is on
Old Apr 3, 2006 | 09:09 PM
got an amp you can switch out? and did this happen all of a sudden?
Old Apr 3, 2006 | 09:32 PM
Well i believe it has done this from the start and the amp is a used one... Probaly came from the pawn shop..LOL...........
Old Apr 3, 2006 | 09:40 PM
djfrestyl's Avatar
Suspension Yoda
Sigh...yet another example of why to purchase from an authorized dealer with warranties intact.
Old Apr 3, 2006 | 10:16 PM
Yes, he must learn! But does not care much... said only paid 200 bucks for 2 jl 10's and the amp plus box
Old Apr 4, 2006 | 07:45 AM
djfrestyl's Avatar
Suspension Yoda
So now he paid $200 for two 10's, a box, and a paperweight.
Old Apr 4, 2006 | 07:59 AM
nismos14's Avatar
§è~® f®ÈÄk
Well even products that have been purchased from authorized dealers aren't necessarily the problem. In this situation there could be something else causing the power wire/amp to drain power. I had the same problem in my 240sx. Removed the ghey cap and the problem dissappeared.
Old Apr 4, 2006 | 08:02 AM
djfrestyl's Avatar
Suspension Yoda
Start isolating wires man. Leave power and ground with no remote overnight.
Old Apr 4, 2006 | 11:01 AM
gonna check into it
Old Apr 5, 2006 | 08:50 PM
talisman311's Avatar
What you're trying to diagnoise is termed parasitic draw. Not really going to get into specifics, but you'll need a meter that measures current to test for this.
In general, most meters have another hole you plug the red probe to in order to test fo this. Anyhow, set the meter on DC current, take off the negative battery terminal. Attach (+) end of meter to the (-) of the battery, and the (-) of the meter to the ground cable of the car. Oh yeah, make sure everything's off...shut all doors etc.. and check for current flow. Might have to wait awhile before everything shuts off. Wait a few minutes and what you want is around 40 milliamps...which is .005 amps.
gigabyte
Jan 6, 2017 06:05 PM
Forge277
Jun 13, 2016 09:26 PM
bigfrank
Oct 1, 2015 12:51 PM
