weird system setup..help
Old Apr 18, 2006 | 05:52 PM
SurraTT's Avatar
HR Swap Pioneer
i recently bought a 92 se, it has a clarion 400x4, powering a bass tube 8in and the rear 6x9's, it also has a kenwood 200x2 powering the fronts
i had alpine type r 12 DVC4ohm, and a xpolde 600 4chnl
i wanted to use the type r with the clarion and the xplode powering it, so i gooked 1 to each coil, and it sounded like crap,
so then i combined the wired before hooking them up and the xploid cut off
how can i wire it where i have 2 amps going to a DVC sub? is this possible, is this not going to give me more powr like im thinking
if its not possible ill just use the type r and the bass tube, but i would rather have 2 amps to they type r, cuz i know the xplode is was underpowering it
thanks for the help, i know its kinda un usuall to have 2 amps to 1 sub
Old Apr 18, 2006 | 06:39 PM
djfrestyl's Avatar
Suspension Yoda
I don't suggest it at all.
Old Apr 18, 2006 | 08:26 PM
Fast1one's Avatar
Thats just stupid sorry....use one amp ONLY. Preferbly a two channel so you can wire the sub in a series and bridge the amp to be sure your getting the same amount of power to each coil...
Old Apr 18, 2006 | 08:35 PM
WhiteMaxima9600's Avatar
Yeah that sounds like a bad idea........ Stick with one amp for both subs
Old Apr 19, 2006 | 03:18 AM
SurraTT's Avatar
HR Swap Pioneer
ok works for me,
seemed ok cuz the amps are really weak so its not like im pushing a lot of power
Old Apr 19, 2006 | 05:06 AM
djfrestyl's Avatar
Suspension Yoda
So now it works?
Old Apr 19, 2006 | 05:07 AM
djfrestyl's Avatar
Suspension Yoda
Weak or not weak doesn't matter, btw. You can blow subs because they're underpowered.
Old Apr 19, 2006 | 05:54 AM
SurraTT's Avatar
HR Swap Pioneer
im just going to use the clarion on the type r and use the xplode on the bass tube ill see how they sound together
Old Apr 19, 2006 | 06:24 AM
nismos14's Avatar
§è~® f®ÈÄk
The type r should be plenty of bass for you what do you need the tube for? if its that bad get a better sub wetup but don't run two different types of subs.
Also you cannot add two channels of amps from different amps to one coil. That will burn up one or both of the amps as the output from one wil not match the other. Only a handful of amps are able to do that, and niether one of your amps can do that.
Miket2006
Mar 1, 2021 03:55 AM
MichMaxFan
Sep 30, 2015 09:18 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
