PA amps......any good?
Old Apr 21, 2006 | 09:12 PM
WhiteMaxima9600's Avatar
Does anyone here have experience with power acoustik amps? If so, how good are they, I know there not very high $ amps and that's good.... but what's good about buying a nice good looking high power "cheap" amp..
Not looking for a killer amp, just something that performs well and is realiable in the heat.. So far i've seen gothic, and power series from PA...
Old Apr 21, 2006 | 09:18 PM
Pearl96Max's Avatar
I tend to get a bit irritable
posta budget and we will try to help. Otherwise keep saving up. Better to do it right the first time, it does end up being less expensive in the end.
Old Apr 21, 2006 | 09:33 PM
I would like to stay $300 or less... All i can afford to play with or i will be shot lol.... I need at least 250-300rms watts
Thanx
Old Apr 21, 2006 | 10:01 PM
Pearl96Max's Avatar
250-300w @ what impedance?
Old Apr 21, 2006 | 10:07 PM
Well i would like to run at 4ohm, but to get this I have to wire series/parallel as u know... so maybe 600x1 @4ohm or so
Old Apr 21, 2006 | 10:13 PM
Pearl96Max's Avatar
refresh my memory on the subs/configurations again.
Old Apr 21, 2006 | 10:26 PM
(2)comp vr's, dvc 4ohm subs.........wired into 4ohm mono
subs wired series/parallel to amp
Old Apr 21, 2006 | 11:40 PM
PaGxe's Avatar
Humm if you run them at series the speakers will be 8 ohms and parallel will be 2 ohms. Maybe you’re thinking of having the speakers run in parallel and then bridge the amp?
Old Apr 22, 2006 | 02:40 AM
Pearl96Max's Avatar
how do you figure that? DVC4..series..8Ohm, then parallel..4Ohm.
Old Apr 22, 2006 | 09:13 AM
PaGxe's Avatar
3am
no sleep
and
Old Apr 22, 2006 | 09:51 AM
If there run in parallel and then bridged that would equal a 1ohm load, and that's not a good thing for my amp.. According to the jl audio tutorial i can wire a series/parallel config.. and have a 4ohm load to one channel... Still get 200watts each, but at 4ohm instead of 2 which makes my amp much cooler..
Anyways back to the original question about PA's
Old Apr 22, 2006 | 09:13 PM
Guess know one owns one of these huh?
Old Apr 22, 2006 | 11:14 PM
nismos14's Avatar
§è~® f®ÈÄk
We do know of them, they suck.
Old Apr 22, 2006 | 11:19 PM
slickrick's Avatar
do it right the 1st time...they are not bad amps but not considered good by any means.
Old Apr 23, 2006 | 09:19 PM
Recommend me something good but not too expensive... I can't invest hundreds of dollars in it but i don't want to get a horrible brand either..
Old Apr 24, 2006 | 04:50 AM
nismos14's Avatar
§è~® f®ÈÄk
Arc Kar 900.1.
Old Apr 24, 2006 | 09:24 AM
I've got don checking to see what he's got..
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
Adoubi21
Dyno Discussion and Slips
Sep 7, 2015 09:34 AM
