Help! Sub started making random popping noises
Old Apr 23, 2006 | 02:55 PM
wariow's Avatar
I recently started having a problem with my sub setup. It started making loud random popping noises. Just loud thuds like somebody is stuck in the trunk. I'm running a 12' diamond audio macdaddy on a 250/1 JL mono amp. Could it be a bad ground or a connection? Bad amp? Sub (the sub is pretty old) I took out the sub and jiggled the wires but can't reproduce the sound. The noise also happens more often on bumps but even when i'm parked idle it happens as well. Any ideas on what can be causing this?
Old Apr 23, 2006 | 03:41 PM
AscendantMax's Avatar
it happens at any volume level? sounds like something is loose. recheck all connections.
Old Apr 24, 2006 | 08:35 PM
wariow's Avatar
yes, this happens at any volume, even when there's no music playing but the HU is on
Old Apr 24, 2006 | 08:49 PM
djfrestyl's Avatar
Suspension Yoda
Sounds like a loose connection, or wires picking up a signal. Are your RCA's taped?
boomerbrian
Nov 8, 2015 05:10 PM
maxinout93
Oct 27, 2015 01:29 PM
seesole
Aug 26, 2015 11:22 AM
egali045
Aug 16, 2015 01:19 PM
kirkhilles
Aug 8, 2015 10:53 AM
