Trunk dampner how much?
Old Apr 25, 2006 | 10:47 AM
WhiteMaxima9600's Avatar
I'm about to order some second skin damplifier for the rear deck, and trunk lid and was wondering about how much would do it? Would the 20sq ft. be enough? Sorry if this is posted already
I heard this is the best stuff for heat, performance, etc.......
Old Apr 25, 2006 | 11:10 AM
nismos14's Avatar
§è~® f®ÈÄk
40 sq ft. Check the FAQ's and the stickies lots of info up there.
swowlinc's Avatar
1993 SE
It depends. 20 should do the lid and rear deck, but you might as well go for the 50 ft. off ebay so you can have some left over for other areas and places where you may need to double up. plus after you do those two places, you may have to do it in other spots because the air is moving to different spots. Now that Ive done my trunk, I can feel tremendous air coming out of my window cracks when they are rolled down. feels like A/C!
good luck, I used Fatmat. It is good.
Old Apr 25, 2006 | 11:13 AM
nismos14's Avatar
§è~® f®ÈÄk
Uh how does dampening cause the air to move in different directions? Unless of course you sealed off the rear deck or something....
Old Apr 25, 2006 | 12:08 PM
swowlinc's Avatar
1993 SE
Well yeah, thats exactly what I did. not only covered the metal but closed all the holes and gaps too...Except for the 2 openings where the subs used to be. sounds mUUUUUCH better. I gotta turn the volume up all the way to hear a pittance of rattle, and Im pushin a fosgate 1500bd!!! nuff said??
Old Apr 25, 2006 | 12:23 PM
nismos14's Avatar
§è~® f®ÈÄk
Gotcha, so your advice to him only applies if he does what you did.
Old Apr 25, 2006 | 12:59 PM
Thanks for clearing that up for me Got 20ft of secondskin on the way, may get more if needed...
Old Apr 26, 2006 | 04:18 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
You should have ordered 80.
Trunklid - 20sqft to hit it internally and the 'chassis'. Spray foam for the internal channels
Rear deck - 20 sqft. for 2 layers on top, 1 layer underneath
Trunk - 40 sqft for a trunk deadening.
...in all honesty, you could likley get away with just hitting the trunklid and rear deck.
Old Apr 26, 2006 | 11:10 AM
That was my intentions to just do the trunklid and rear deck.... Main source of my rattles and vibrations are those two... I don't see any need and going all out at this time with a mild system
Old Apr 26, 2006 | 11:13 AM
slickrick's Avatar
don't worry give it time and you will deaden more.
Old Apr 26, 2006 | 11:22 AM
lol.. yeah your probaly right, I usually start out small with things then before u know it i'm going all out
Why do I get myself in these situations?
Old Apr 26, 2006 | 11:44 AM
nismos14's Avatar
§è~® f®ÈÄk
That's because you've caught the bug called Car Audio.
Old Apr 26, 2006 | 11:48 AM
I've caught many bugs in my life, seems to always be the "expensive" ones
REDinLV
Aug 15, 2024 12:30 AM
mrgooch
Sep 21, 2015 08:43 PM
lux97Max
Sep 14, 2015 07:07 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
rbaker100
Sep 6, 2015 02:46 PM
