Easiest way to remove the bose sub cover + sub?
Old Apr 30, 2006 | 08:40 AM
6SpeedTA95's Avatar
Hey guys I wanna remove the bose sub since I got my system installed. It no longer fuctions but I can't seem to get the cover off and i dont wanna break it because I plan on keeping the cover in place. HELP!
Old Apr 30, 2006 | 08:53 AM
filtor1's Avatar
What year Maxima?
Old Apr 30, 2006 | 09:06 AM
6SpeedTA95's Avatar
2002 Maxima
Old Apr 30, 2006 | 09:08 AM
6SpeedTA95's Avatar
I can't for the life of me see how that cover comes off without removing the carpet and I dunno thats its worth it for that.
Old Apr 30, 2006 | 09:17 AM
filtor1's Avatar
It actually just pops out. If I remember corectly the BOSE name can be read (is right side up, facing you) when you are in the back seat looking toward the rear. Get a flat headed screwdriver and place it under the top edge (the top of the BOSE emblem) and lift up enough to get a finger under the grill. Pull straight up. Doing this under the BOSE emblem will not work due to the plastic pieces the hold the grill to the rear deck. Hope this helps.
Old Apr 30, 2006 | 09:46 AM
6SpeedTA95's Avatar
Pulling it straight up wont break clips or anything?
Old Apr 30, 2006 | 10:48 AM
6SpeedTA95's Avatar
Got it done thanks! Any suggestiosn for removing the Bose Amp?
Old Apr 30, 2006 | 10:52 AM
djfrestyl's Avatar
Suspension Yoda
It should be mounted behind the trunk carpet...10mm bolts I'd imagine.
Old Apr 30, 2006 | 11:00 AM
6SpeedTA95's Avatar
Yes sir it is, the question is how the hell do I get under the carpet without tearing it? It may not even be worth it honestly...but I'd like to sell the blose on ebay...even if I dont have an amp
Old Apr 30, 2006 | 03:41 PM
filtor1's Avatar
Ther are several clips that hold the carpet in place. Remove them and the carpet will move out of your way.
Old Apr 30, 2006 | 04:01 PM
6SpeedTA95's Avatar
Cool thanks, are the clips the white pointed clips stickin down into the trunk?
Old Apr 30, 2006 | 05:19 PM
nismos14's Avatar
§è~® f®ÈÄk
SO how does the new setup sound? What did you end up putting in?
Old Apr 30, 2006 | 05:42 PM
6SpeedTA95's Avatar
It sounds REALLY good, I had to have ultimate do the install but they really did a great job. It sounded good enough that they wanted me to put the car out in front of their store next weekend as a "demo" but since I live about 60 miles away and already had plans I told them no :hsd:
Infinity 6.5's in the doors, pioneer 680MP deck, fosgate punch2 (I know you guys think its a piece of ****) and an alpine amp powering the sub at 220watts RMS. I can always pop a new sub in the box later so I went with the cheap one for now.
Old Apr 30, 2006 | 09:09 PM
filtor1's Avatar
Wait, do you mean the carpeted rear deck or the carpet that lines the trunk?
To remove the rear deck you have to remove three black trim pieces that are visible when the back seat is folded down. Remove the C-pilars, then you will have access to the rear deck for removal. I am assuming those were the white pointed things you were refering too. The ones that secure the rear deck(partical board) to the actual rear shelf(sheet metal).
For some reason when you said carpet, I assumed you were refering to the trunk liner. I appologize if I understood.
Old Apr 30, 2006 | 09:15 PM
djfrestyl's Avatar
Suspension Yoda
Bose amp is behind the carpet in the trunk, the trunk liners. They have clips that you have to half-unscrew, half-pop
The bose sub (obviously) is under the rear deck, which is clipped to the metal rear deck with white clips, that yes, face downward into the trunk.
Dunno who's confusing who
Old May 1, 2006 | 05:30 AM
6SpeedTA95's Avatar
No problem man
Old May 1, 2006 | 05:44 AM
nismos14's Avatar
§è~® f®ÈÄk
Glad it worked out well for you. As long as you like the sound you're getting thats all that matters. How much did it all run you?
Mar 12, 2020 12:06 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
carid
Sep 17, 2015 05:00 AM
Colossus
Sep 9, 2015 05:46 AM
