My driver side door speaker works WHEN IT WANTS..
Old May 2, 2006 | 11:48 AM
BaDMaNDUNK's Avatar
REXXX
I'm trying to figure out why my door speaker only works sometimes. I originally purchased my 03 max used with aftermarket speakers, but the driver door speaker wasn't working at all. One day i decided to check it out by removing the door panel and taking out the speaker.. I tested the speaker with a 9volt battery and i got no response.. i figured that since i had no money for a new speaker right away that i wuld just put it back in and reconnect it.. so i did.. now, it just works whenever it wants to. sometimes i start the car and its thumping right away.. other times i would start the car and it would be completely dead at first, until im half way to my destination and i feel the thump again. it jus works on and off. im assuming it could be something wrong with the wiring.. any suggestions?
Old May 2, 2006 | 11:55 AM
AscendantMax's Avatar
take the speaker out, and look at the two tinsel leads that's going into the center of the cone. see if they're still intact.
Old May 2, 2006 | 11:56 AM
djfrestyl's Avatar
Suspension Yoda
Swap it out with another speaker.
Or just meter the wires and see if its getting a variable signal
If you tested the speaker with a 9v and it didn't work, doesn't that tell you it's the speaker itself?
jskirwin
Jun 8, 2016 08:49 AM
rtirbany
Sep 8, 2015 11:46 AM
shaunkey1
Aug 18, 2015 10:09 PM
KGMtech
Aug 18, 2015 09:21 AM
