Subwoofer Hookup
Old May 17, 2006 | 02:49 PM
99 SE Limited's Avatar
Subwoofer Hookup
I have a 99 Maxima SE with a Bose headunit. I would like to hookup two 10" Infinity subs, but I am not sure what the outs are and what cords I will need. Can anyone help me, plus I will need directions about getting the head-unit removed.
Old May 17, 2006 | 03:57 PM
djfrestyl's Avatar
Suspension Yoda
Start reading the stickies. You need a standard amp wiring kit that comes with RCA's (or separate RCA's) and an extra set of 6 inch cheapy RCA's (female) that you will chop.
Old May 18, 2006 | 08:02 AM
Bollwerk's Avatar
Get a Haynes or Chilton manual for $20-ish. They helped me ALOT when I did my system install. Note that the Chilton only goes to '98, but the 99 is basically the same. (I have the Haynes)
Old May 18, 2006 | 10:10 AM
nismos14's Avatar
§è~® f®ÈÄk
Just read the stickies, no need to buy the manual unless there's other work you plan to do.
Old May 19, 2006 | 03:26 PM
k3v's Avatar
k3v
sry for jacking the thread..but i cant create any. i was just wondering if i could use the red power wire in the rear speaker of a bose system as the amp turn on wire.
Old May 19, 2006 | 09:19 PM
djfrestyl's Avatar
Suspension Yoda
Read the stickies. Wire colors are there.
Old May 20, 2006 | 06:52 AM
k3v's Avatar
k3v
i know what the wire colors are.. i looked it up in the Haynes manual...but what im asking is if i could use the power wire for the bose rear speaker as a turn on wire for my aftermarket amp.
Old May 20, 2006 | 06:55 AM
djfrestyl's Avatar
Suspension Yoda
Use the Bose turn on wire instead.
Old May 20, 2006 | 07:18 AM
k3v's Avatar
k3v
is that the only option? because i didnt really want to take out the headunit. im kinda lazy and i figured that the power wire in the rear would give the 12v power that the amp needed. it would be alot more work to run a new wire from the head unit to the trunk. but i will use the bose turn on if the rear speaker power wire is unsuitable
Old May 20, 2006 | 07:23 AM
djfrestyl's Avatar
Suspension Yoda
Before you use it, test it to see if its constant or switched. If its constant and you use it for a remote turn on, then your amp will always be on, which will drain your battery.
How far are you from Tampa/Gainesville? Theres an org member out there that I highly recommend to help you with your install.
And to add, taking out the HU is really not that hard or time consuming.
Old May 20, 2006 | 07:28 AM
k3v's Avatar
k3v
tampas about 3 hours away and gainsville is way too far. plus im still young, 17, and under parental watch...so i doubt i would be able to drive across the state to see a stranger. and yea ill test it first...
Old May 20, 2006 | 07:37 AM
djfrestyl's Avatar
Suspension Yoda
Alright, I don't know the geography of FL...
Let us know what your findings are. I know that behind the radio, remote turn on is white/green. It may be the same at the amp.
Old May 20, 2006 | 07:43 AM
kpr10is's Avatar
Thank you sir
Fbana41
Aug 29, 2016 12:18 PM
jskirwin
Jun 8, 2016 08:49 AM
sliptap
Sep 30, 2015 05:57 AM
