02 Bose HU removal?
Old May 24, 2006 | 06:54 AM
6spBlkMax's Avatar
02 Bose HU removal?
So maybe Im a maxima noob..... I cant figure out how to get the Bose HU out!!! I have tried searching the help links in the stickies and the only thing i can find on it i have to pay for the info. I know lots of you guys have done this so some free advice would be much appreciated. I just dont want to break anything trying to get it out.
By the way im only a noob to maximas.... but i know a little bit about car stereo install. Have done it in numerous cars before. Thanks in advance!
Old May 24, 2006 | 08:38 AM
MIXXMAX's Avatar
It's really simple. Start at the gear shift plate. It's best if you turn on the car for a minute and put the car in low gear (low 1 or low 2...this will help to get the trim over the shifter.) Insert a thin screwdriver in either rounded corner of the shift plate and pull upward until you have grip on it. Pull upwards and slide the plate away from the center panel underneath the A/C. Remove all harness connections from back of trim. Next, remove the A/C vent trim from top. Take two hands and grab the inside of vents and pull towards yourself. Pull hard because the clips are really secure. Next remove four bolts holding the radio bracket in. Remove all harness connections from behind and your done. If your're planning to remove the Bose HU from the bracket, be prepared that those bolts are on there extra, extra tight. Nissan seems to "locktite" those bolts in the bracket. You may even have to cut them off. That's what I had to do to mine. Good luck!
Old May 31, 2006 | 02:49 PM
NBP-RSX-617's Avatar
I cant find any good DIY's here? Is it me?
Old May 31, 2006 | 03:56 PM
djfrestyl's Avatar
Suspension Yoda
Yes, it's you.
Old Jun 1, 2006 | 08:53 PM
westfall's Avatar
If you put a screwdriver in the bolts and hit them with somthing they will break lose, does that make sense?? Oh, Well does to me.
Old Jun 2, 2006 | 06:05 AM
djfrestyl's Avatar
Suspension Yoda
Use a #2. Tighten, then loosen.
Old Jun 2, 2006 | 11:58 AM
DcMaN's Avatar
+1 For djfrestyl you really need the correct phillips head for those screws
Old Jun 2, 2006 | 01:45 PM
deftpunk's Avatar
I had my head unit on the ground putting all my weight on the screw driver just to get the screws out.....they really seemed to strip easily! I probably didn't have the exact match for the screws tho.
tighten, then loosen is what worked for me too.
Old Jun 2, 2006 | 03:15 PM
djfrestyl's Avatar
Suspension Yoda
#2 screwdriver tip for good contact.
Tighten till you hear a click. That indicates the screw's "seal" has been broken. You will be able to loosen after that.
Old Aug 17, 2006 | 09:40 AM
dutchmanx's Avatar
It's a bit too late but I am sure someone will need this info.
Step-by-step instructions here:
http://www.installdr.com/InstallDocs...PDF/647021.pdf and here:
http://ahsan.fotopic.net/c191230_1.html
Old Aug 17, 2006 | 11:59 AM
burnurass's Avatar
You're missing ONE IMPORTANT STEP which may cause him to BREAK SOMETHING or make him feel like a retard when he's doing it. Open the coin tray next to the hazard switch...pull out the insert. Behind that there's a screw..unscrew it. THEN you can do what you said to do.
Old Aug 17, 2006 | 12:00 PM
burnurass's Avatar
Installdr needs a password
second link is for a 4th gen.
Old Aug 18, 2006 | 08:53 AM
dutchmanx's Avatar
not for me
Old Sep 1, 2006 | 01:38 AM
Chaka's Avatar
Zulu
not for me either
RealityCheck
Oct 2, 2015 06:34 PM
sliptap
Sep 30, 2015 05:57 AM
jaydot901
Sep 29, 2015 01:18 PM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
