Replacing speakers on 5.5 Maxima
Old May 24, 2006 | 07:47 AM
spark plugs.'s Avatar
Hi, I drive a Maxima.
did a quick search but i couldn't find anything.
is there a how-to for replacing the speakers?
if i don't plan on adding an amp to the new speakers, would i still have to run new speaker wires into the door?
Old May 24, 2006 | 08:28 AM
nismopc's Avatar
No. the gauge of the factory speaker wire is fine if your using the stock hu and in most cases, they are still fine even with an aftermarket head unit. When you start to push more power thru the wires from a high power amp, then it's recommended to upgrade the speaker wires at that time.
kpr10is's Avatar
Do you have Bose? (or did you previously) Do you already have an aftermarket radio? If so, how is it installed, i.e. a Pac/Scosche adapter, wired with RCAs, etc.
In either case, the answer would be no, you dont have to run new speaker wire. And the factory grommet in the door is a harness anyway, through which it is near impossible to run anything. But we will need answers to the above questions to help you further.
Old May 24, 2006 | 05:10 PM
yes, i did have bose, but i have installed a kenwood head unit. i can't remember which harness i used.
Old May 24, 2006 | 06:26 PM
djfrestyl's Avatar
Suspension Yoda
So you're still running the Bose speakers?
Then no you can't just swap out your speakers. You would have to run new speaker wire or bypass the Bose amp.
jskirwin
Jun 8, 2016 08:49 AM
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 11, 2015 12:23 PM
Mcnabb34
Aug 11, 2015 08:45 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
