Have a system in your Max?
Old Jun 6, 2006 | 11:31 AM
BergundyMax's Avatar
This may coincide with my previosu thread but i have a system also in my car....i think the guy may have wired it wrong, because I got it rewired and now, the bass is wayyyyyy to strong.....I can barely hear the words on any song, so my brother said if I get new hi's that it should fix the problem....any other insight from anyone else with a system?
P.S.- the ledge under my back windsheild rattles a lot tooooo :-/
Old Jun 6, 2006 | 11:35 AM
SoonerFan's Avatar
Cletus
post this where it belongs http://forums.maxima.org/forumdisplay.php?f=25
Old Jun 7, 2006 | 07:37 AM
nismos14's Avatar
§è~® f®ÈÄk
You asked the same damn question again. You don't want just new highs, new highs = tweeters. You need new mids and highs. Get a good set of components speakers up front and an amp. You'll be set.
Old Jun 7, 2006 | 07:54 AM
burnurass's Avatar
stupid question...but did yuo try turning the gain down on the amp so it's not so overpowering?
Old Jun 7, 2006 | 09:10 AM
djfrestyl's Avatar
Suspension Yoda
MFin
And we can better help you if you post what products you are running?
Old Jun 7, 2006 | 09:23 AM
yes I have the **** all the way down on the amp so its not overpowering.....I am currently running 2 12 Rockford Fosgate Punches, with an 800 watt rockford fosgate amp
Old Jun 7, 2006 | 10:15 AM
Bollwerk's Avatar
What speakers do you have in the front/rear? What amp is powering them? Are they coaxials or components? Do you have a crossover or hpf/lpf used on the amp? If so, where are the crossover/hpf/lpf points? Slopes? ....etc....
Old Jun 7, 2006 | 10:17 AM
nismos14's Avatar
§è~® f®ÈÄk
What ****? Bass **** or the GAIN on the amp?
Old Jun 7, 2006 | 10:19 AM
burnurass's Avatar
maybe he turned the crossover ****...who knows?
Old Jun 7, 2006 | 11:15 AM
nismos14's Avatar
§è~® f®ÈÄk
But that wouldn't be just the bass getting alot louder.
Old Jun 7, 2006 | 11:40 AM
03SE2HEAR's Avatar
My guess is he's running two 4 Ohm woofers in parallel and bridged on a Punch amp.
Kinda helps to have the model numbers on the product he's using.
Old Jun 7, 2006 | 03:14 PM
HitManSE's Avatar
Bass... too strong If you can still see or breath easily, its not too loud. You just need a frontstage that can keep up with it.
Old Jun 7, 2006 | 04:48 PM
ahaaa...i turned down the bass **** outside the amp, but my friend let me know there is a **** in the actual amp if I unscrew the front....thanks all
Old Jun 8, 2006 | 05:36 PM
03SE2HEAR's Avatar
What kind of RF amp? If you have to take the sheetmetal off to get to this bass ****, then you might just be messing with the bias pots inside.
Old Jun 8, 2006 | 06:23 PM
claudiusmaximas's Avatar
hahaha good to know.
Old Jun 9, 2006 | 09:24 AM
yes very good to know....well im gonna go with new speakers for now....and I will update you guys when I get changes
Old Jun 23, 2006 | 08:12 PM
Hexon's Avatar
I had the same problem when my rear polks coaxials were in for warranty replacement. The 2 12" subs were way too strong for the speakers up front. When I got them back, I amped them and the music is perfect now. Also, make sure the gain is set right. Bass boost should only be set for around 6db unless you are trying to look big and bad with your road vibrating bass. the bass boost doesnt just turn up the bass, it exagerates it and throws it off a bit. If you are looking for perfect sounding music use around 6db bass boost.
Old Jun 23, 2006 | 08:18 PM
AscendantMax's Avatar
pefect sounding music shouldn't require any boost at all
Old Jun 23, 2006 | 08:19 PM
djfrestyl's Avatar
Suspension Yoda
Word up. Properly set levels/gain >>>>>> Bass Boost all day long
Old Jun 24, 2006 | 09:05 AM
nismos14's Avatar
§è~® f®ÈÄk
Bass boost at 6 db is DOUBLE the standard amount of bass compared to a non-processed signal, if you think that is better than a flat signal.... you're smoking some crack.
DJLAX152
May 4, 2021 11:46 AM
captchaos
Mar 15, 2016 12:18 PM
carid
Sep 9, 2015 05:06 AM
MaxLife17
Sep 8, 2015 02:36 PM
pktaske
Sep 4, 2015 08:40 AM
