Terminal Oxidation
Old Jun 12, 2006 | 08:35 PM
AscendantMax's Avatar
Terminal Oxidation
What the hell causes it? Before putting in my power cable, my battery terminals are fine. But now it's starting to oxidize around the ring terminal connecting to my 4 gauge. I can't see this from a chemical standpoint. Oxygen in the air is why metals oxidize, some faster than others depending on the metal. But how come it was fine until I installed the system?
Does the current draw have anything to do with it?
Old Jun 12, 2006 | 08:39 PM
djfrestyl's Avatar
Suspension Yoda
Fuzzy washers FTW.
edit: or just stick stamps all over the terminal to cover it up.
Old Jun 12, 2006 | 08:41 PM
Fuzzy washers FTW.
haha sorry I ran out of stamps
Old Jun 13, 2006 | 01:00 PM
nismos14's Avatar
§è~® f®ÈÄk
Rofl......... u can spray some anti corrosion stuff on it, and it'll eat away the corrosion.
Old Jun 13, 2006 | 01:07 PM
SgtSchulze's Avatar
Burn Dust. Eat my rubber.
Just use some clear soda (7-up) and some baking soda. Middle School Science FTW!!
Seriously, after you get them clean..run down to the autoparts store and pickup some terminal protection spray. It's a small can for less than $5 and it's the red stuff that comes from the factory.
Old Jun 13, 2006 | 02:33 PM
yeah, i neutralized the area with baking powder and water solution, and covered it up with some dielectric grease.
but the question remains...why did it oxidize after i installed the power cable?
Old Jun 13, 2006 | 09:03 PM
HitManSE's Avatar
Yeah water will work just fine, you can take it apart and just scrub it at that point to get rid of any excess. Its caused by the battery acid slowly evaporating/seeping from the battery , that combined with moisture. Most of the time it pulls toward the positive (+) side.
You can spray some of that anti corrosive sticky stuff on, or just get yourself an dry or gel typed battery that doesnt seep out acid. Mmmmk.
Old Jun 15, 2006 | 05:15 PM
nishfish871's Avatar
The auto parts store sell those little red and green rings pads to help stop corrosion. I put it the last time i changed my battery (over 1 year) and it is clean as can be after one year.
Old Jun 16, 2006 | 01:01 PM
MacGyverS2000's Avatar
I've found that corrosion typically shows up shortly before a battery gives up the ghost... YMMV.
Old Jun 17, 2006 | 09:11 PM
Don't know about that, voltage output is still strong.
AaronL
Nov 15, 2020 11:52 AM
