KEEP BLOWING FUESes?!?!?!
Old Jun 18, 2006 | 08:43 PM
NewEngSurf's Avatar
heres the deal
I have my fairly new alpine mono amp hooked up to my bran new type x sub, slammed for about a month with the amp mounted to the back of my seat. Well it was mounted pretty ****y so i dicided to drill it into the back of my box, so i disconnected all the wires going to it and drilled it into the box , reconnected everything and then i turn the car on and i immediatly blow 2 of the 4 fuses. SO i replace them and then it does it again, and again, and again, I checked all the wires and they are not crossed or anything. One thing i did do was switched my ground from one of the strut mount bolts to another but i did clean up the bolt with a wire brush. What could be going wrong , is my amp toast?!?!?!?!? help?!?!?!
Old Jun 18, 2006 | 08:49 PM
AscendantMax's Avatar
you didn't accidently pinch the speaker wire when you mounted the amp did you? or maybe drilled and damaged the wire inside...
Old Jun 18, 2006 | 09:10 PM
NewEngSurf's Avatar
No, and i also tried disconnecting both the speaker wires/rcas and started the car with just the remote/ground/power wires and still blew the same 2 fuses. I mean i hope this isnt some sort of internal problem? I mean u think if i opened up the amp and started pokin around i could see something busted on the circuit board? If my power wire is some how touching the frame of the car it would short out the amp correct? but i would figure it would blow all 4 instead of the same 2. Anyone else with a little more electrical knowledge PLEASE step in with anything.
Old Jun 19, 2006 | 12:16 AM
eh, i rather not open the amp if you're not familiar with electronics. so you basically moved the amp from the seat, to the box, reconnected everything and now it won't work? i would double check the lines again to see if they're secured, or not accidently damaged.
what amp is this btw?
Old Jun 19, 2006 | 05:24 AM
djfrestyl's Avatar
Suspension Yoda
Take the amp back off the box. Clearly its cursed.
Or what I'd do is pull off the sub and see if your screws are hitting anything.
Old Jun 19, 2006 | 05:42 AM
DcMaN's Avatar
one of the screws that the amp is being mounted with could be touching the magnet of the subwoofer, what size screws did you use ?
Old Jun 19, 2006 | 07:19 AM
Bollwerk's Avatar
Beware mounting an amp to a sub box. The vibrations from the sub can damage/loosen the electronics inside the amp over time.
Old Jun 19, 2006 | 09:46 AM
myth, the amp can take those vibrations fine.
Old Jun 19, 2006 | 10:18 AM
djfrestyl's Avatar
Suspension Yoda
fact, Gordon is not an advocate of stamps
Old Jun 19, 2006 | 10:30 AM
fact: I will never hear the end of these stamp remarks
Old Jun 19, 2006 | 12:03 PM
nismos14's Avatar
§è~® f®ÈÄk
Fact; fueses = non-existant.
Old Jun 19, 2006 | 09:27 PM
bunna203's Avatar
your power wire must be grounding out. double check to see if itz pinch or xposed to the frame
Old Jun 19, 2006 | 09:37 PM
IIDMOII's Avatar
is the sub a dual 2 ohm or 4 ohm....
Old Jun 19, 2006 | 10:18 PM
shouldn't matter. his system was fine until he relocated the amp.
Old Jun 20, 2006 | 12:15 PM
IIDMOII's Avatar
true... but the same thing happened to 1 of my friends.... it worked for a few weeks and then started blowing fuses.... found out that the amp couldnt handle the load from the subs....
Old Jun 20, 2006 | 12:28 PM
MIXXMAX's Avatar
Double check all your wires to make sure they didn't get pinched or anything and touching metal. Make sure your mounting screws on your amp aren't touching anything behind them. Get a DMM and check all the leads going to the amp--power, remote turn on, ground, and speaker wires. This will definitely tell you if there is a short somewhere. As far as mounting amps to a sub box, it will be fine. Vibrations do not cause an amp to perform badly. Just as long the sub is made out of 3/4" or more MDF, it will be fine from vibrations. I used my sub box for over 8 years for my amp rack and never had a problem.
Old Jun 20, 2006 | 03:25 PM
NewEngSurf's Avatar
Hey guys, i really apprciate the input and u guys have given me some good ideas. Im really hoping that one of the screws is touching the sub. Sorry i havent gotten back to u guys, i just had my orientation for the past to days at the university of rhode island. I JUST got home. Ill keep you posted, by the way this is the amp if it helps. http://www.alpine-usa.com/en/product...odel=MRD-M1005
Old Jun 20, 2006 | 08:18 PM
NewEngSurf's Avatar
Success........I <3 the org, thanx guys i feel like an idiot now, I was so busy checking my wires/ground/connections that i didnt bother to take the amp off the box. One of the screws must have periced one of the speaker wires inside, i didnt take out the sub and look but the screws wernt long enough to touch the magnet.
Old Jun 21, 2006 | 04:22 AM
djfrestyl's Avatar
Suspension Yoda
Of course that was the problem
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Noela
Sep 26, 2015 08:22 AM
jwright36
Sep 8, 2015 11:45 AM
