Do 4th gen Bose Decks have an outlet for a bass tube?
Old Jun 20, 2001 | 01:19 PM
maxtypeser's Avatar
Actually have one laying around and figure I might as well try to get it in my max... was wondering do I need any special adapters or nething? Thanx
Chieh
Old Jun 20, 2001 | 02:25 PM
maxtypeser's Avatar
Bump
Bump!
Old Jun 21, 2001 | 03:01 PM
Botos's Avatar
This would be better answered in the Car Audio forum, but the short answer is no outlets. Your best bet would be to get a line-level adapter which taps off the rear speaker wires, then a cross-over to filter it to just the low frequencies. Bose does some funny things with their speaker voltage levels, though, so you may also need another adapter to go from Bose levels to normal ones.
Old Jun 24, 2001 | 12:36 AM
pawn's Avatar
i have a bazooka bass tube in my car, and ill i did to install it was tap into the power wire on each amp of the rear speakers in the trunk, then i tapped into the +/- of each speaker, and ran the wires so you couldnt see them....then i had them come up underneath the carpet, and just made a small incision for the wiring harness on the tube to go down through....then i just connected all the wires underneath the carpet, and made a ground right near that......and i was done......whole thing only took like 30min....its a snap....and it sounds really really good......i was very impressed!
Old Jun 24, 2001 | 04:36 PM
ray89se's Avatar
bass tubes
i lovem got 4 passive one's inthe trunk hits pretty hard and stil haveenough room for junk
MAXSE5SPD
Sep 17, 2022 04:00 AM
6spd4dsc
May 9, 2022 12:30 PM
A32goldylocks
Sep 2, 2015 06:39 AM
Lowered_a33
Sep 1, 2015 07:49 PM
