need help w/ pioneer ipod adapter
Old Jun 24, 2006 | 10:31 AM
raidwolf's Avatar
i have a pioneer avic n3. my hide-away is mounted under the front passenger seat. i just ordered/received david navone's ipod adapter kit (see http://www.autosound2000.com/ipodadapters.htm) which plugs into the hide-away's IP bus port and has a hot and ground wire. where in the passenger floor board can i find a 12v?
Old Jun 24, 2006 | 06:28 PM
djfrestyl's Avatar
Suspension Yoda
You MAY find it in the heated seat wires.
Otherwise, it's really not that hard to tap off the ignition and run a wire.
Old Jun 24, 2006 | 06:35 PM
kpr10is's Avatar
Why wouldnt you just get the ipod adapter made by Pioneer instead of some off brand?
Anyway, modules made by Pioneer get switched power through IP Bus and constant and ground are external, so assuming this one works the same, youll need constant power, which is why Id guess that heated seats won't work, but I could be wrong. I say run em up to the ignition harness or radio's harness and call it a day.
Old Jun 25, 2006 | 06:56 PM
raidwolf's Avatar
after all the times i've pulled out the passenger seat and head unit, i think i'm going w/ the pioneer ipod unit. right now, i have the hot wire extended to the hu's switched power. the ipod would start charging, then after a few minutes it wouldn't charge. maybe it's the way i ran/tapped the wires, so i'm starting to get frustrated. i know it's easy, but electrical ain't really my thing. live and learn, huh.
Old Jun 25, 2006 | 07:30 PM
djfrestyl's Avatar
Suspension Yoda
Make sure your wires are fully tapped. T-taps (if you're using them) sometimes don't bite 100%. Try stripping and splicing the wire directly in line.
Old Jun 26, 2006 | 03:28 AM
raidwolf's Avatar
that's exactly what i've done - i used vamp clips just to test what wire works, then as soon as i found it, i spliced directly into it and wrapped w/ elec tape. what i'm finding out is if my ipod is less than 50%, it'll charge, but after a few minutes of charging, it'll stop. it seems that this adapter won't charge to 100%... maybe the pioneer brand will.
magiconthetire
Oct 26, 2015 09:03 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
jaydot901
Sep 29, 2015 01:18 PM
