Help with adding sub and amp to bose
Old Jun 24, 2006 | 03:14 PM
Saddles's Avatar
Okay so I have the bose system. I've been trying all day to add subs to my car, with little luck. I tried a line level input from before the bose sub amp to the sub and after. We're not getting a very strong input signal. Tried splicing RCA's straight to input wires to the bose sub amp, a little louder, not much. Tried signal from a rear speaker, a little louder, not much. Whats the deal? I have a 2002 SE with bose 6disc btw.
Old Jun 24, 2006 | 04:16 PM
RA030726's Avatar
I'm nutty for Nissans
do you have some sort of line level converter?
Old Jun 24, 2006 | 05:39 PM
Scope's Avatar
Im izz sexay
First mistake is bose hu.
Seriously though does your amp have a high level converter. If it does then you are in luck. All you need to do is splice the rear speaker + and - connect them to the amps harness and go from there. If not then you should just get a better HU.
Old Jun 24, 2006 | 06:40 PM
djfrestyl's Avatar
Suspension Yoda
Sure your gains are set correctly?
Old Jun 24, 2006 | 08:39 PM
Pearl96Max's Avatar
I tend to get a bit irritable
what amp/speakers?
Old Jun 24, 2006 | 10:39 PM
Saddles's Avatar
Gain is fine. I was using a line level converter, but as I said, it was worse than without. I'm going to be going bose for a while, my pioneer 9600mp went with my old car. My amp is the rockford fosgate 1000bd and my sub is a 15in eclipse titanium. Thanks for any additional input.
Old Jun 25, 2006 | 09:41 AM
maxgtr2000's Avatar
KH3 by popular demand
I just used a line level converter. Remove the screws from the bose amps that hold it onto the speaker, you will see the speaker wire terminals the wires (outputs from the bose amp) are red and green on my 97. I tapped into those and it works perfect. I just use the bose mids and a class d sub amp for now. I set the gains on the converter the way the directions say and use the front/rear fader for a gain as well.
Old Jun 25, 2006 | 10:00 AM
Saddles's Avatar
I tried that tooo, didn't work as well as tapping into a rear speaker....i dunno, im confused really, It just seems I'm getting like no preamp output voltage...welll...very little...
Old Jun 25, 2006 | 11:03 AM
Scope's Avatar
Im izz sexay
By any chance does your amp have a high pass, full, or low pass crossover. Check to see if it's on high pass or full. You need to have it on low pass and set the frequency.
Old Jun 25, 2006 | 07:19 PM
Saddles's Avatar
All that stuff is set...it was beating good in my 4th gen, the only thing different is the head unit thats giving it signal is the bose, not my pioneer. Is there a preamp output amplifier? Anyone else have an idea? I'm still researching
Old Jun 25, 2006 | 07:28 PM
djfrestyl's Avatar
Suspension Yoda
You *should* get a decent signal out of the Bose. It is by no means strong or clear, but it's been utilized by many people with no issues. If you gain is set the same from your Pioneer HU, by switching to Bose you WILL have to raise your gain.
Old Jun 25, 2006 | 10:25 PM
Saddles's Avatar
Yeah I know, i've been fiddling all day yesterday and today... I think im going to try a different sub and amp...i know theres nothing wrong with mine, i just have a feeling it is a setup requiring a little more than the bose wants to give it...i can barrow my old 10s back with a 500 watt amp to see if the difference in amps is any help... how do we go about using bass blockers on our highs with the bose? normally...orrrr
Old Jun 26, 2006 | 04:50 AM
djfrestyl's Avatar
Suspension Yoda
1. Why would you need a bass blocker?
2. Get a line driver.
Old Jun 26, 2006 | 05:19 AM
Timothios's Avatar
I agree! You must get a line driver. Line drivers are usually needed when you tap into a factory system.
Old Jun 26, 2006 | 10:29 AM
Saddles's Avatar
I was thinking a bass blocker to cut out even more frequencies from my highs. I dunno maybe I'm crazy. Lack of sleep is getting to me...I realized after I posted a crossover would be way more appropriate...but a line driver huh? I'll look into that.
Old Jun 26, 2006 | 10:32 AM
djfrestyl's Avatar
Suspension Yoda
Your Bose system already has crossovers/filters in place for your tweeters and mids. You only have to worry about crossing over your aftermarket sub(s) at the correct point.
Old Jun 26, 2006 | 01:05 PM
Saddles's Avatar
Will this do what I am looking for? Should I go with a higher quality one? Or will that pretty well do it? I see lots of recommendations for PAC products in the stickies so I'd imagine this will do quite well....thanks for all of your help guys, I appreciate it a lot.
http://cgi.ebay.com/Pac-Turbo-1-Turb...QQcmdZViewItem
Old Jun 26, 2006 | 01:37 PM
djfrestyl's Avatar
Suspension Yoda
That would be the one, although I'm never a fan of purchasing off ebay.
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
