Solobaric 10" dust cover loose. Adhesive?
Old Jul 4, 2006 | 04:11 PM
nismopc's Avatar
Messing around with a round Solobaric C10 sub and after installing into a .61cf sealed box, I noticed there is a slight seperation of the dust cover and the woofer that allows air to pass thru it when the cone is pushed on.
I attempted to use Super Glue, but it did not hold at all.
Will this effect the performance of the woofer? Any ideas on how to fix it?
Only other idea I have is to run a bead of polyurethane caulking around the entire dustcover.
Old Jul 4, 2006 | 04:17 PM
nismopc's Avatar
Also, there is not enough room to pull the dust cover up to add adhesive to the back of it. Only large enough to slide a piece of paper under it.
Old Jul 4, 2006 | 05:05 PM
Hexon's Avatar
Gorilla Glue is the bomb! I was able to almost completely fix a busted subwoofer with Gorilla Glue. It was able to hold the voice coil to the cone of the woofer. I was pretty impressed.
Old Jul 4, 2006 | 07:45 PM
filtor1's Avatar
ca is the only way to go.
Old Jul 5, 2006 | 02:44 AM
nismopc's Avatar
Old Jul 5, 2006 | 09:46 AM
filtor1's Avatar
http://www.ides.com/generics/CA.htm
This is just one of the sites I found while doing a quick google search. There were several though.
CA or cellulous acetate, is what the manufacturers use to "glue" the various moving part of a sub either together or to the basket itself. It is typically black in color, although other colors can be found, and is used folloed by an accelerator to speed up the hardening process.
Old Jul 5, 2006 | 12:19 PM
Hexon's Avatar
Gorilla Glue is used to glue metal to metal, cement to cement, cars to the ceiling, etc. It is clear in color too.
Old Jul 5, 2006 | 12:42 PM
RockfordMax's Avatar
Back from the dead
gorilla glue didnt do shyt when I tried to use it to fix the cone seperation on my bose 6.5's...... Not sure whether or not it will work with a sub or not.
Old Jul 5, 2006 | 12:58 PM
nismopc's Avatar
Thank you. I saw a new product made by SuperGlue that had a accelerator and the glue. It was specifically stated to work with all plastics.
I am going to hook it up and see how it sounds. Then I'll decide if I want to attempt to seal it off.
Old Jul 5, 2006 | 01:00 PM
Hexon's Avatar
Did you give it time to dry?
Old Jul 5, 2006 | 06:35 PM
filtor1's Avatar
Too bad you weren't closer. I have a bottle at the shop. I don't know anything about the SuperGlue brand though.
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
doctorpullit
Mar 29, 2016 11:08 AM
jonreidhead
Jan 6, 2016 09:38 AM
londonflu
Sep 19, 2015 02:33 PM
