Trunk rebuild worklog pics...beginning
Old Aug 5, 2006 | 06:48 PM
  #41
nismos14's Avatar
§è~® f®ÈÄk
Looks good!!!
Old Aug 5, 2006 | 08:05 PM
  #42
DukeDuke's Avatar
Unless I am not understanding your install... it will look good in the trunk, but like a$$ in the rear deck... your going to have them inverted, magnets up, subs face in the trunk? Not to bad... just gonna look kinda half a$$ from inside if I am seeing your plans correctly... unless your gonna lay glass on the inside too. Oh well... good luck
Old Aug 6, 2006 | 02:33 AM
  #43
BBOYSTEVIE's Avatar
Back from Hibernation
The one place that you're right is that your not understanding my install....
1. For the thrid time (at least) the magnets facing down, subs firing up into the cabin. Have you done any reading or just looked at pics and posted this comment?
2. Yes Of course I'm glassing the rear deck. Do you think I'd do all this and stop there and leave it looking that way instead of taking a few extra hours and making a new rear deck? Hello? Amyone home? If I wanted, I would be able to get away with simply putting the stock rear deck on over it actually, but no I'm not...I'm glassing it.
3. Please post some custom work you've done before you come on here and tell my my stuff is gonna look like crap when it's chopped up half way done.
Constructive criticism and advice from people that can offer tips cause they actually install are welcome..Jerkoffs hating who after all this still don't really get what I'm doing NOT welcome
Old Aug 6, 2006 | 05:54 AM
  #44
Jay_Alix's Avatar
Originally Posted by BBOYSTEVIE
Now the dissapointing pic. You can see the lights under where the top amp will be real well, but the others, I think, don't have enough room to really shine. I'll see how much room I have tomorrow....One way or another, it'll still be neat and clean (for me, at least), just not light up as much as I wanted.
I did something simmilar with my amps and signal processor, but using LEDs. I was less than thrilled with the results as well. However it did end up being closer to what I had imagined once mounted in the car. One thing I did was to cut sections of the carpet out underneath the amp mounts and use "chrome" spray paint with the hope that this would help reflect light instead of the carpet absorbing it. I don;t know how much this actually helped though. Mine only have 3/4" spacing between the amp and rack.
Old Aug 6, 2006 | 05:56 AM
  #45
djfrestyl's Avatar
Suspension Yoda
Steve how close are your CCFL's to the edge of the rack? Can you move them outwards or are you trying to go for the effect that only the light is shown, not the actual tube.
Old Aug 6, 2006 | 06:17 AM
  #46
Metal Maxima's Avatar
SHIFT_om nom nom nom
QFMFT.
Looking good, dude. Can't wait to see the progress.
Old Aug 6, 2006 | 07:09 AM
  #47
nismos14's Avatar
§è~® f®ÈÄk
Some people, jeebus. How about giving some credit rather than idiotic stuff like that?
Old Aug 6, 2006 | 10:22 AM
  #48
BBOYSTEVIE's Avatar
Thanks for the support. I am trying to keep the actual tubes not shown, but get more light. DJfreestyle, you're right. I think I can move em out to the end a little, and maybe cut out some of the carpet overhang to get a lil more light coming out. If only my amps were one inch longer I could put them all the way on the ends. The yellow LED's I've found first off ended up looking orange, and not putting out much light. Actually of all color LED's and cold cathodes, yellow seems to be the least vivarent. Actually, I've heard that white reflects light best? Maybe a lil white paint may be in order. I think today I'm gonna let that be and reinforce the "tub" some.
Thanks again for your support. I woke up, read that, and hadn't even had my coffee yet.
Hey Metal......two things
1. What does QFMFT mean?
2. You gonna offer advice to save me some sanding? Planning to vinyl the part visable in the trunk and maybe (though possibly not cause of time and money) paint the "inside" of the tub. I'm dreading getting that perfect finish.
Old Aug 6, 2006 | 03:48 PM
  #49
BBOYSTEVIE's Avatar
After the lights not looking as I wanted yesterday, I really wanted to do something different today, and feel like I got something accomplished, so I did the structural build up of the "tub".
Last time I built a sub enclosure, instead of ordering knytex as I was told to, I used a combo of roving from a boat shop, and mat and thin cloth. Well lemme tell you, compared to that, the knytex was a PLEASURE to work with. It does great around corners, builds up real thick real quick, and from an economic point of view, uses resin very efficiently. I thought I'd be able to put on a layer/layer and a half then run out and get more resin (only had just under a gallon), but instead with that less than a gallon, I was able to put on a full 3 to 4 coats of knytex (supposedly 2 is enough).
I would have taken more pics of the in progress, but i have messy gloves on, fiberglass resin hardening, and anyway, a monkey could do this part. Just cut it up into different shapes you'll need ahead of time....
If its the first coat, put a little resin on there to help her stick, then dab the resin on till its all wet. In this pic a few big pieces are on and need just a lil more time on there and a lil more resin brushed on to be done with.
Gosh the knytex made it easy. Didn't form into air bubbles or anything.
Tomorrow I'm gonna get out the grinder (should have done some of this today before glassing) and take off any extra little pieces that aren't needed (extra fleece from the forming, or extra left over around the baffle), make sure the baffle is well glassed on, maybe give a layer to the inside, and do some strength testing (jump on it a lil).
Unbelievable, this knytex stuff. The total buildup took maybe an hour or two and less than a $25 gallon of resin.
Old Aug 6, 2006 | 04:38 PM
  #50
mendon99's Avatar
tastey wheat
QFT = Quoted for truth
QFMFT = Quoted for mother... well you get it.
again, anxious to see results bboy, make sure you take lots of pics when you're done!
Old Aug 6, 2006 | 04:43 PM
  #51
BBOYSTEVIE's Avatar
You can count on it. Definately getting closer!
Old Aug 8, 2006 | 05:35 AM
  #52
KUBLKMAX's Avatar
Ok...mold is made for the sub tub. Not going to reinforce it until I get in the speaker wire that I'm going to run "through" it (in the backside that you won't really see). That, I find out, will be Monday or Tuesday cause the one place that had the yellow speaker wire I want is taking it's time....sooooo
turning my attention back to the amp rack...test fit time, and time to figure out how to mount fourth amp in front so it doesn't look too stupid...
Pic of the back of the amp rack...example of how wires will run through it. Only wire shown is from the cold cathodes, just an example...
holes on top for RCA's, holes on bottom for power/ground/remote/and speaker wires
Pic of how I'm "raising" the amps a little under an inch to fit the cold cathodes "behind" the amps, and will have the wiring appearing from behind too....Appropriate sized coupling nuts (same size as screw and t-nuts used) allow me to raise the amps with NO wiggle at all. Cathodes will be better mounted, of course....
This is a total bite off of Don's idea when he mounted my big 4 channel amp before. He used 2x4's to raise it up off the other amps. I'm doing essentially this, just mounting it at an angle and am going to take measures to mount it so hopefully there's no wiggle. Got a point deducted at SVR because the top amp could move a little, so I'm going to glue it, then I'm gonna screw it,then finally I'm gonna use L brackets to secure it
Pic of 2x4's that will be used to raise 4 channel amp in front of others
About the angle the 4 channel amp will lay over other amps, with lights behind it of course...
All of this will be carpeted in black, of course, but everythings gotta be in order before that happens....
OK gonna go fasten and glue those 2x4's, make a few holes for the 4 channel wiring, and let it dry overnight....then it should be ready for carpeting and final mounting of the wood that will hold the amps!
Hey Steve
Where did you get those post you are using to hold up your amps in the top picture?
Old Aug 8, 2006 | 05:57 AM
  #53
MannyNJ2k2max's Avatar
Looking good buddy!You are brewing others creative juices, its coming along!
Old Aug 8, 2006 | 06:20 AM
  #54
BBOYSTEVIE's Avatar
Originally Posted by KUBLKMAX
Hey Steve
They're called coupling nuts. I found them at home depot. They have that little section with metal/steel. In that section they have lotsa steel squares, rods, and flat steel. Hanging in that section are the little 99 cent bags of em, so I just got em in the exact size of bolt I was using for a tight fit, and of course long enough to house the cathodes underneath. If you need more funky sizes, do a google for coupling nuts and there's tons of em around. For some reason I think I remember seeing a decent selection at a boating strore recently????
Manny: Thanks. I hope people can get ideas or learn from my mistakes or what bit of knowledge I've picked up from my own mistakes.
Yesterday I took the carpeting off the bottom amps, painted the top's sides black (so the carpet underneath isn't blocking light from getting out), and moved the lights as far outside as I could get them. Definately helped a bit. I have one light not working, but have a replacement that I'll put in today.
Waiting for a freaking check to clear so I can get more resin, then I'll finish the tub, work on a covering, and put it all together. Still getting there, but slowly but surely. I have a buddy coming down next week who has agreed to be my install ***** and help with some work a little, and I'm hoping to get help on vinyling from Mic Wallace if he can squeeze in the time...if not watch out, it would prolly be fugly. Never vinlyed before.
Old Aug 8, 2006 | 12:01 PM
  #55
JOHNSONCL_78's Avatar
Hay bboy how did you solve the problem of the trunk lid. I have an 03 and want to do the same thing but with 12 in the rear deck how do you keep the trunk up after you cut out the sway bars.
Old Aug 8, 2006 | 01:08 PM
  #56
BBOYSTEVIE's Avatar
Check out this thread I did and feel from to PM me with any questions you have
http://forums.maxima.org/showthread.php?t=424338
Or to answer your question simply, gas shocks from a local auto parts store.
Old Aug 8, 2006 | 01:18 PM
  #57
BBOYSTEVIE's Avatar
K, trying to get somewhere, but this SUCKS!
First off, the little bit of progress made on redoing the lights behind the amp plates
One light is out, and it wasn't actually that dark. whether the picture shows it or not, when I turned on the lights after taking out the carpet and moving lights further outside, I was much happier with it. Just gotta replace one burnt light. No biggie
Now to today..back to the sub tub. First I cut off extra big protrusions on the bottom. Below you can see some of the protrusions left and others still yet to be cut off...I'm sure a better installer could have skipped this whole step
Not shown, i filled large bends on the bottom with duraglass, put a layer of resin/knytex around the "inside" of the tub where the baffle meets glass and where the wood rear deck meets glass....just more reinforcement.
Now to the part that sucks, and this is where I'm going where I haven't really gone before.....Trying to sand this biatch down for vinyling...After big gaps were filled in with duraglass, i smoothed lightweight filler over the whole thing and have started sanding. Dude, my hand hurts real bad, and i'm only on 40 grit sanding still! I have a lotta sanding left, and prolly a few little areas that will need to be refulled and resanded Here's where I am now....
And to think I was actually thinking about sanding and trying to paint the inside of this thing...HELL NO. Anyway, if anybody wwith more experience doing this type of stuff (cough cough Don, Metal Maxima, Kublimax) wants to drop me some hints or pointers here, this would be a great time. My hands hurt.
Old Aug 8, 2006 | 01:28 PM
  #58
mendon99's Avatar
tastey wheat
Metal Max has a thread somewhere for this exact experience, id contact him..
looks good
btw bboy, YGPM
Old Aug 8, 2006 | 01:33 PM
  #59
BBOYSTEVIE's Avatar
Right back at ya
Old Aug 8, 2006 | 02:14 PM
  #60
westler92
Your shiznit looks great. I wish you all the luck in the world.
Old Aug 8, 2006 | 06:38 PM
  #61
maxgtr2000's Avatar
KH3 by popular demand
Looks good man but you need an air/orbital sander, hand sand the small stuff. Trust me it will save you alot of time.
Old Aug 8, 2006 | 08:20 PM
  #62
BBOYSTEVIE's Avatar
Yeah I have one that I only had some sanding discs for. Didn't do well on the crevaces at all. What I really need is an air compressonr, but anyways, I think I'm just gonna carpet it to match the rest of my interior Easier, and will match better, but just not as cool...
Old Aug 8, 2006 | 09:44 PM
  #63
2 Da Max's Avatar
nice project u got gonig on there BBoy
Old Aug 9, 2006 | 03:18 AM
  #64
Steve - I'll give my $0.02 when I get home from work today.
Old Aug 9, 2006 | 07:42 AM
  #65
BBOYSTEVIE's Avatar
Thanks man, but I'm going with carpet.
Old Aug 9, 2006 | 11:52 AM
  #66
NO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!
j/k
Gotta stick to a common theme...
Old Aug 9, 2006 | 04:40 PM
  #67
BAH, if you insist...
Old Aug 9, 2006 | 04:46 PM
  #68
djfrestyl's Avatar
Suspension Yoda
The foam can still be used with carpet...
Old Aug 9, 2006 | 04:51 PM
  #69
BBOYSTEVIE's Avatar
not necessary, especially after all that sanding.
Old Aug 9, 2006 | 04:56 PM
  #70
I'd hilghy recommend it...unless the carpet has a backing...
Old Sep 14, 2006 | 03:00 PM
  #71
Dave Gardner's Avatar
that's friggin awesome, i can barely get my boxes square!
REDinLV
Aug 15, 2024 12:30 AM
James92SE
142
Jan 2, 2024 09:23 AM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
Pied
Sep 26, 2015 03:29 PM
